[Mapserver-users] problems with ms 3.7
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Thu Jan 2 12:28:42 EST 2003
About the WMS/WFS parameters ...
Actually, it is quite possible to have WMS and WFS using quite different
parameters .... For example, projection and re-projection handling in those
2 specs are different, which creates the requirement of setting the SRS type
parameters differently depending on which protocol you're using.
Also, for abstracts, I can also see the need to have seperate ones, the
description of a WMS and a WFS can be quite different, since they basically
do quite different things really.
I guess MAYBE the title could be unified :) (But for consistency it won't !)
This was implemented in such a way that one could potentially use a given
mapfile to serve both WMS AND WFS, but in such a case, the mapserver
developper really should NOT make any assumptions on how similar or
different you (the service provider) want to make them look. I personally
NEED them to be different for example, simply because the plain english
desciptions are very diffferent, and the projection handling being
different, I need those seperate as well.
My .02$
J.F.
-----Original Message-----
From: Stepan Kafka [mailto:stepan.kafka at centrum.cz]
Sent: Thursday, January 02, 2003 9:19 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] problems with ms 3.7
Hi all,
I am testing mapserver 3.7 from 30.12.02 (GD 2.1, GDAL-CVS version, TTF 2,
WMS + WFS servers...) on Linux RH 8 machine, but found some problems:
- wider lines (size > 1) made by "circle" symbol have black thick
"outlines". This error I found only in RGB/RGBA mode, in PC256 everything is
OK.
- It seems that label MAXSIZE parameter doesn't work with scaled symbols.
The labels are zoomed without limits.
- Offset lines (e.g. STYLE OFFSET 5 -99) are drawn once on the one side of
the original line, once on the other side. Is this OK? (Using absolute
values of dx, dy?)
- The STYLE is very good for complex symbols, but I don't how can I set e.g.
width polygon outlines (old OVERLAYOUTLINECOLOR syntax)?
- for WMS and WFS are introduced these paremeters in the mapfile, e.g:
WFS_TITLE, WMS_TITLE, WFS_ABSTRACT, WMS_ABSTRACT, WFS_SRS, WMS_SRS. I expect
that these pairs have the same content in most cases. Wouldn't be reasonable
to use them only once for both services?
Thank you
Stepan Kafka
Help Service Remote Sensing
tel: +420-327514118
mailto:kafka at email.cz
http://www.bnhelp.cz
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
