[Mapserver-users] Fastest Data Format
GAIA
mapserver at peligroso.gaiaenv.com
Fri Jan 3 14:06:43 EST 2003
Hi Jan,
Great news and thanks for your efforts.
The persistent connection option may or may not be desirable. On the one hand, the persistent connection would reduce connection initiation overhead, but on the other hand, in an Internet environment we may not want a seat occupied by a web client for any longer than it takes to render a map. Strictly speaking from an SDE point of view, licenses are limited and we want to return them to the pool as fast as possible to make way for other requests. From a PostGIS perspective, things might be different. Probably, Paul is the best person to comment on this (?).
Again, please let us know if we can help in any way (e.g., testing with SDE).
Cheers,
GAIA
>I just got connection pooling running (Happy New Year!), but I can only
>test it against PostGIS here. As expected, it doesn't make much
>difference there (17 vs 14 seconds for a map with 100 layers), but for
>SDE and OracleSpatial it should cut substantially more ice. I'll send
>the code to Steve Lime and the PostGIS and OS folks for testing and if
>they agree it can be put into CVS. Unless I made some terrible mistake
>this should not take much time: the whole thing takes about 50 lines in
>the main code and about 5 lines for each of the database interfaces.
>Moreover, there is no need to change all database interfaces at the same
>time: an unchanged interface will run as before.
>Note however that connections are pooled ONLY within a single map (i.e.
>a single MapServer request). Every new map (e.g. for zoom or pan) has to
>open a new connection (which will be used subsequently for all layers in
>that map). I'm not sure if this will be adequate for SDE and OS. At
>first sight, I have no idea how to keep open a connection between map
>requests. Do people know how ArcIMS/SDE and OS manage this (if they do
>it at all)?
>Jan
