[Mapserver-users] Compile/library problems
m.spring at gmx.de
m.spring at gmx.de
Mon Jan 6 16:38:25 EST 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Jean-Francois.Doyon at CCRS.NRCan.gc.ca writes:
> But you're going to have a bigger problem. The system linker on your ISP's
> server isn't going to find the librairies it wants to dynamically load. To
> get around this, either you get them to update their linker paths
> (ld.so.conf), which is unlikely they would do, or you use your own linker
Just a shot in the dark: This should be configurable with the
environment variable LD_LOAD_PATH. At least Apache allows to set
Environment variables for CGI skripts, but you have to see the docs.
Markus
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Processed by Mailcrypt 3.5.6 and Gnu Privacy Guard <http://www.gnupg.org/>
iD8DBQE+GfdRxxUzQSse11ARAiHJAKCC7LzijAw+1oehGXfMr52kUr9qgACePZ7+
oS4xuons+9ikA1HXHmNaEZg=
=Nd2t
-----END PGP SIGNATURE-----
