[Mapserver-users] Compile/library problems
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Mon Jan 6 16:42:40 EST 2003
Very true, hadn't thought about that, but again, his ISP *might* object
about that ...
If they don't, they can use the SetEnv configuration directive in apache to
set LD_LIBRARY_PATH ...
J.F.
-----Original Message-----
From: m.spring at gmx.de [mailto:m.spring at gmx.de]
Sent: Monday, January 06, 2003 4:35 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Compile/library problems
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Jean-Francois.Doyon at CCRS.NRCan.gc.ca writes:
> But you're going to have a bigger problem. The system linker on your
ISP's
> server isn't going to find the librairies it wants to dynamically load. To
> get around this, either you get them to update their linker paths
> (ld.so.conf), which is unlikely they would do, or you use your own linker
Just a shot in the dark: This should be configurable with the
environment variable LD_LOAD_PATH. At least Apache allows to set
Environment variables for CGI skripts, but you have to see the docs.
Markus
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Processed by Mailcrypt 3.5.6 and Gnu Privacy Guard
<http://www.gnupg.org/>
iD8DBQE+GfZ6xxUzQSse11ARAvYtAJ0S9+P9W+YCJGYTcFIIWBTZOEZXpACeJsaU
9myYI/xMq8tAahYoiJ3vbUc=
=8neL
-----END PGP SIGNATURE-----
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
