[Mapserver-users] Projections
Ed McNierney
ed at topozone.com
Fri Jan 10 13:52:09 EST 2003
John -
If you create a simple MAP file that specifies no projection at all, do you get a different result than if you specify that PROJECTION block?
Is it possible that you're displaying the image in an IMG tag that's got a HEIGHT and WIDTH explicitly specified?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Friday, January 10, 2003 1:46 PM
To: Mapserver-Users
Subject: [Mapserver-users] Projections
How are projections handled in map server? When I use: PROJECTION
"proj=longlat"
"ellps=GRS80"
END
The image seems to be sheared or stretched in the north south direction.
The data I am using is in lon/lat coordinates.
Thanks
John
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
