[Mapserver-users] Projections
John McCue
jmccue at geovue.com
Tue Jan 14 12:21:45 EST 2003
I am still trying to get a correct projection in MapServer. I have defined
a PROJECTION object in the MAP object to use an EPSG code:
PROJECTION
"init=epsg:26986" #Massachusetts Mainland State Plane, NAD83
END
I have also defined that same projection in each of my layers. My data is in
geographic coordinates (lon/lat).
My problem is that the image appears to be contracted from north to south.
- Are my projection specifications correct?
- Is this a different problem, maybe setting the image size?
Thanks for any help,
John
