[Mapserver-users] Allother probles solved - still woking on the PIXEL_SIZE calculation
Silke Reimer
silke at intevation.de
Mon Jan 13 02:59:13 EST 2003
--gKMricLos+KVdGMg
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
Content-Transfer-Encoding: quoted-printable
Hi Steve,
if you apply the following patch to the mapserver, you can get the
pixelsize within your template with the tag [cellsize].
I hope that helps,
=09
Silke
On Wed, Jan 08, 2003 at 01:18:51PM +0800, Steve McCrone wrote:
> Hi again,
>=20
> I guess you could call it the 'Reverse Murphy Law'. Once I mail my questi=
on/problem to the list, I still continue trouble shooting and, through sear=
ching previous questions and trial and error, come up with the solution. So=
, currently my project works with the rosa applet, which zooms, pans etc. I=
can turn layers on & off using checkboxes, my map dos not zoom or pan duri=
ng the toggling on/off of layers. My buttons retain their state after map r=
edraws (i.e. submits). My next un-resolved issue is calculating the PIXEL_S=
IZE to used in the measurement calculation. I'm really trying to avoid get=
ting involved in PHP an wish to achieve all my functionality strictly with =
mapserv and rosa - so far so good.
>=20
> So if anyone out their can shed some light on the PIXEL_SIZE issue that w=
ould be great.
> Steve
Here is the patch:
diff -ur mapserver-3.6.2.orig/maptemplate.c
mapserver-3.6.2/maptemplate.c
--- mapserver-3.6.2.orig/maptemplate.c Mon Aug 12 08:48:30 2002
+++ mapserver-3.6.2/maptemplate.c Mon Aug 12 08:53:50 2002
@@ -1963,6 +1963,8 @@
=20
sprintf(repstr, "%f", msObj->Map->scale);
outstr =3D gsub(outstr, "[scale]", repstr);
+ sprintf(repstr, "%f", msObj->Map->cellsize);
+ outstr =3D gsub(outstr, "[cellsize]", repstr);
=20
sprintf(repstr, "%.1f %.1f", (msObj->Map->width-1)/2.0,
(msObj->Map->height-1)/2.0);
outstr =3D gsub(outstr, "[center]", repstr);
--=20
Silke Reimer
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
--gKMricLos+KVdGMg
Content-Type: application/pgp-signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.0 (GNU/Linux)
iD8DBQE+InHR1W4oD4nfjasRAiDsAKDJa8aFj8EH8hEThhUHKvV6lGRJ7wCg4pzV
9zzWzdWTKu5MJT29oscdAX0=
=ZrqD
-----END PGP SIGNATURE-----
--gKMricLos+KVdGMg--
