[Mapserver-users] Strange Label Problem
John Deck
jdeck at socrates.Berkeley.EDU
Mon Jan 13 11:57:10 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0004_01C2BAE1.C2192170
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
I am using the ESRI County Shapefile Layer (that comes with ArcView
3.1). I am able to label counties successfully using the mapfile that I
have posted below. It works for all counties that I have tested except
for "Nevada County" in California. It Labels Nevada County Arkansas
but not the one in California. I've tested cases where there are
multiple county names from different states and they work fine. I have
also ported the data over to postgis and checked the topology and
everything seems fine. Also, I've tried every combination of label
parameters that could affect drawing labels.
This is frustrating because it is apparently random and only fails with
Nevada County. Any help/advice on people who have encountered similar
behaviour would be appreciated! I'm using Mapserver 3.6 on Redhat 7.3.
The shape file is at:
http://bnhmdev.berkeley.edu/test/data/counties.zip
And a demo is at:
http://bnhmdev.berkeley.edu/cgi-bin/mapserv?map=/usr/local/apps/html/map
script/sa_map3.map
<http://bnhmdev.berkeley.edu/cgi-bin/mapserv?map=/usr/local/apps/html/ma
pscript/sa_map3.map&mode=map&layer=us_county> &mode=map&layer=us_county
Following is my mapfile:
MAP
EXTENT -149.454 -5.81713 -64.9307 78.781
IMAGETYPE PNG
SIZE 400 400
UNITS DD
NAME "SA_MAP2"
SHAPEPATH "../test/data"
PROJECTION
"proj=latlong"
END
WEB
IMAGEPATH "/usr/local/apps/html/tmp/ms_tmp/"
IMAGEURL "http://bnhmdev.berkeley.edu/tmp/ms_tmp/"
LOG "/tmp/sa_map2.log"
MAXSCALE 500000000000
MINSCALE 1
END
LAYER
NAME us_county
STATUS ON
TYPE POLYGON
STATUS DEFAULT
DATA counties
CLASSITEM "name"
LABELITEM "name"
LABELMAXSCALE 500000000
LABELMINSCALE 1
SIZEUNITS PIXELS
TEMPLATE "template.html"
TOLERANCE 3
TOLERANCEUNITS PIXELS
TYPE POLYGON
UNITS METERS
CLASS
COLOR 255 0 100
EXPRESSION "Nevada"
LABEL
COLOR 255 255 0
MAXSIZE 256
MINSIZE 1
TYPE BITMAP
SIZE TINY
COLOR 100 0 0
FORCE TRUE
MINDISTANCE 1
MINFEATURESIZE 0
PARTIALS TRUE
POSITION AUTO
END
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 255 0 0
SIZE 1
SYMBOL 0
END
END
END
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C2BAE1.C1A502E0">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"State"/>
<o:SmartTagType =
name=3D"PlaceName"/>
<o:SmartTagType =
name=3D"PlaceType"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:UseFELayout/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:"MS Mincho";
panose-1:2 2 6 9 4 2 5 8 3 4;
mso-font-alt:"\FF2D\FF33 \660E\671D";
mso-font-charset:128;
mso-generic-font-family:modern;
mso-font-pitch:fixed;
mso-font-signature:-1610612033 1757936891 16 0 131231 0;}
@font-face
{font-family:"\@MS Mincho";
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"MS Mincho";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>I am using the ESRI County <span =
class=3DSpellE>Shapefile</span>
Layer (that comes with <span class=3DSpellE>ArcView</span> 3.1).<span
style=3D'mso-spacerun:yes'> </span>I am able to label counties =
successfully
using the <span class=3DSpellE>mapfile</span> that I have posted =
below.<span
style=3D'mso-spacerun:yes'> </span>It works for all counties that =
I have
tested except for “</span></font><st1:place><st1:PlaceName><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>Nevada</span></font></st1:Pl=
aceName><font
style=3D'font-size:10.0pt;font-family:Arial'> =
</span></font><st1:PlaceType><font
style=3D'font-size:10.0pt;font-family:Arial'>County</span></font></st1:Pl=
aceType></st1:place><font
style=3D'font-size:10.0pt;font-family:Arial'>” in =
</span></font><st1:State><st1:place><font
style=3D'font-size:10.0pt;font-family:Arial'>California</span></font></st=
1:place></st1:State><font
style=3D'font-size:10.0pt;font-family:Arial'>.<span
style=3D'mso-spacerun:yes'> </span>It Labels =
style=3D'font-size:10.0pt;font-family:Arial'>Nevada</span></font></st1:pl=
style=3D'font-size:10.0pt;font-family:Arial'> County =
</span></font><st1:State><st1:place><span
class=3DGramE><font size=3D2 face=3DArial><span =
Arial'>Arkansas</span></font></span></st1:place></st1:State><span
Arial'><span style=3D'mso-spacerun:yes'> =
</span>but</span></font></span><font
style=3D'font-size:10.0pt;font-family:Arial'> not the one
in </span></font><st1:State><st1:place><font size=3D2 face=3DArial><span
style=3D'mso-spacerun:yes'> </span>I’ve tested cases where =
there are
multiple county names from different states and they work fine.<span
style=3D'mso-spacerun:yes'> </span>I have also ported the data =
over to <span
class=3DSpellE><span class=3DGramE>postgis</span></span> and checked the =
topology
and everything seems fine.<span style=3D'mso-spacerun:yes'> =
</span>Also,
I’ve tried every combination of label parameters that could affect
drawing labels.<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>This is frustrating because it is apparently random =
and only
fails with </span></font><st1:place><st1:PlaceName><font size=3D2 =
face=3DArial><span
aceName><font
style=3D'mso-spacerun:yes'> </span>Any help/advice on people =
who have
encountered similar <span class=3DSpellE>behaviour</span> would be
appreciated!<span style=3D'mso-spacerun:yes'> </span>I’m =
using <span
class=3DSpellE>Mapserver</span> 3.6 on <span =
class=3DSpellE>Redhat</span> 7.3.<o:p></o:p></span></font></p>
font-family:Arial'>The shape file is at:<o:p></o:p></span></font></p>
font-family:Arial'><a =
href=3D"http://bnhmdev.berkeley.edu/test/data/counties.zip">http://bnhmde=
v.berkeley.edu/test/data/counties.zip</a>
font-family:Arial'>And a demo is at:<o:p></o:p></span></font></p>
href=3D"http://bnhmdev.berkeley.edu/cgi-bin/mapserv?map=3D/usr/local/apps=
/html/mapscript/sa_map3.map&mode=3Dmap&layer=3Dus_county">http://=
bnhmdev.berkeley.edu/cgi-bin/mapserv?map=3D/usr/local/apps/html/mapscript=
/sa_map3.map&mode=3Dmap&layer=3Dus_county</a>
font-family:Arial'>Following is my <span =
class=3DSpellE>mapfile</span>:<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'>MAP<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>EXTENT -149.454 =
-5.81713
-64.9307 78.781<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>IMAGETYPE =
PNG<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>SIZE 400 <span
class=3DSpellE>400</span><o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>UNITS =
DD<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>NAME =
"SA_MAP2"<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>SHAPEPATH
"../test/data"<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> =
</span>PROJECTION<o:p></o:p></span></font></p>
style=3D'font-size:
</span>"<span
class=3DSpellE>proj</span>=3D<span =
class=3DSpellE>latlong</span>"<o:p></o:p></span></font></p>
style=3D'font-size:
</span>END<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
</span>WEB<o:p></o:p></span></font></p>
style=3D'font-size:
</span>IMAGEPATH
"/<span =
class=3DSpellE>usr/local/apps/html/tmp/ms_tmp</span>/"<o:p></o:p></s=
pan></font></p>
style=3D'font-size:
</span>IMAGEURL
"http://bnhmdev.berkeley.edu/tmp/ms_tmp/"<o:p></o:p></span></fo=
nt></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>LOG
"/tmp/sa_map2.log"<o:p></o:p></span></font></p>
style=3D'font-size:
</span>MAXSCALE
500000000000<o:p></o:p></span></font></p>
style=3D'font-size:
</span>MINSCALE 1<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
12.0pt'>LAYER<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>NAME <span =
class=3DSpellE>us_county</span><o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>STATUS =
style=3D'font-size:
12.0pt'><span style=3D'mso-spacerun:yes'> </span>TYPE =
POLYGON<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'text-indent:6.0pt'><font size=3D3 =
style=3D'font-size:12.0pt'>STATUS DEFAULT<o:p></o:p></span></font></p>
style=3D'font-size:12.0pt'><span style=3D'mso-spacerun:yes'> =
</span>DATA
counties<o:p></o:p></span></font></p>
</span>CLASSITEM
"name"<o:p></o:p></span></font></p>
</span>LABELITEM
</span>LABELMAXSCALE
500000000<o:p></o:p></span></font></p>
</span>LABELMINSCALE 1<o:p></o:p></span></font></p>
</span>SIZEUNITS
PIXELS<o:p></o:p></span></font></p>
</span>TEMPLATE
"template.html"<o:p></o:p></span></font></p>
</span>TOLERANCE
3<o:p></o:p></span></font></p>
</span>TOLERANCEUNITS PIXELS<o:p></o:p></span></font></p>
</span>TYPE
</span>UNITS
METERS<o:p></o:p></span></font></p>
</span>CLASS<o:p></o:p></span></font></p>
style=3D'font-size:12.0pt'><span =
</span>COLOR 255 0 100<o:p></o:p></span></font></p>
</span>EXPRESSION =
"</span></font><st1:State><st1:place>Nevada</st1:place></st1:State>&=
quot;<o:p></o:p></p>
</span>LABEL<o:p></o:p></span></font></p>
</span>COLOR 255 <span class=3DSpellE>255</span> =
</span>MAXSIZE 256<o:p></o:p></span></font></p>
</span><span
style=3D'mso-spacerun:yes'> </span>MINSIZE =
</span>TYPE
BITMAP<o:p></o:p></span></font></p>
</span>SIZE
TINY<o:p></o:p></span></font></p>
</span>COLOR 100 0 <span =
class=3DSpellE>0</span><o:p></o:p></span></font></p>
</span>FORCE TRUE<o:p></o:p></span></font></p>
</span>MINDISTANCE 1<o:p></o:p></span></font></p>
</span>MINFEATURESIZE 0<o:p></o:p></span></font></p>
</span>PARTIALS TRUE<o:p></o:p></span></font></p>
</span>POSITION AUTO<o:p></o:p></span></font></p>
</span>MAXSIZE 100<o:p></o:p></span></font></p>
</span>MINSIZE 1<o:p></o:p></span></font></p>
</span>OUTLINECOLOR 255 0 <span =
</span>SIZE 1<o:p></o:p></span></font></p>
</span>SYMBOL 0<o:p></o:p></span></font></p>
style=3D'font-size:12.0pt'>END<o:p></o:p></span></font></p>
style=3D'font-size:12.0pt'><o:p> </o:p></span></font></p>
style=3D'font-size:
</div>
</body>
</html>
------=_NextPart_000_0004_01C2BAE1.C2192170--
