[Mapserver-users] plot a point on map
Lowell Filak
lfilak at medinaco.org
Tue Jan 14 08:09:17 EST 2003
Yes.
You can either use the projectionObj in Mapscript or a 'system' call to the 'cs2cs' command.
Both require that PROJ.4 is installed and projectionObj requires that MS was compiled with PROJ.4 support.
HTH
Lowell F.
The following message was sent by "nida Khan" <nida at webstar.co.uk> on Tue, 14 Jan 2003 10:42:00 -0000.
> Hi ,
> Thanks to Joost and Lowell I was able to plot the points on my map :).
> now I have another issue, data I have is in eastings and northings...
> Is there any formula that I can use to covert this data so I could plot > it on my map??
> Many Thanks
> Nida Khan.
