[Mapserver-users] Adding php_mapscript
Beth Baily
bbaily at CEMML.ColoState.EDU
Wed Jan 15 09:37:25 PST 2003
Listers,
I have installed and tested PHP4 on my Win2000 workstation with Apache
and cgi mapserver 3.5. PHP4 by itself works fine. I moved
php_mapscript.dll to the php4 extensions directory and set extension_dir
in php.ini to that directory. Then I used phpinfo_mapscript.php to test
it. The output I get in my browser is:
Warning: dl() [function.dl]: Unable to load dynamic library
'd:\php\php-4.3.0-Win32\extensions\php_mapscript.dll' - The specified
procedure could not be found. in d:\program files\apache
group\apache2\htdocs\phpinfo_mapscript.php on line 17
followed by the results from phpinfo().
When I first start my browser and try to run phpinfo_mapscript.php, I
get this error:
The procedure entry point zend_list_addref could not be located in the
dynamic link library php4ts.dll.
I can click on OK and then I see the results described above. I would
appreciate any help.
Thanks,
Beth
More information about the MapServer-users
