[Mapserver-users] Adding php_mapscript
krung
krung at cad.go.th
Wed Jan 15 13:55:02 EST 2003
Hi Beth
Did you use php_mapscript.dll the same version as your PHP? I went to dmsolution a few days ago, I couldn't find php_mapscript.dll with PHP 4.3.0 support.
Krung.
---------- Original Message ----------------------------------
Date: Wed, 15 Jan 2003 10:37:25 -0700
>Listers,
>I have installed and tested PHP4 on my Win2000 workstation with Apache
>and cgi mapserver 3.5. PHP4 by itself works fine. I moved
>php_mapscript.dll to the php4 extensions directory and set extension_dir
>in php.ini to that directory. Then I used phpinfo_mapscript.php to test
>it. The output I get in my browser is:
>Warning: dl() [function.dl]: Unable to load dynamic library
>'d:\php\php-4.3.0-Win32\extensions\php_mapscript.dll' - The specified
>procedure could not be found. in d:\program files\apache
>group\apache2\htdocs\phpinfo_mapscript.php on line 17
>followed by the results from phpinfo().
>When I first start my browser and try to run phpinfo_mapscript.php, I
>get this error:
>The procedure entry point zend_list_addref could not be located in the
>dynamic link library php4ts.dll.
>I can click on OK and then I see the results described above. I would
>appreciate any help.
>Thanks,
>Beth
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
