[Mapserver-users] wms client
Daniel Morissette
morissette at dmsolutions.ca
Thu Jan 16 19:02:25 EST 2003
Brian Clark wrote:
> We've built and installed libwww 5.4.0. However, configure returns:
> "libwww version 5.3.2 or more recent is required"
> Tried it with: --with-wmsclient=/usr/local/lib, and no errors on
> configure or make,
> but also no wmsclient support.
> OS is Solaris 2.6.
Make sure /usr/local/lib is in your path, passing
--with-wmsclient=/usr/local/lib has no effect, and actually in this case
it doesn't even try to locate libwww. You have to use --with-wmsclient
with no argument and it will look for libwww-config in your path.
Also make sure you are using MapServer 3.6.4, there used to be a problem
with the libwww version check that was fixed starting with 3.6.2.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
