[Mapserver-users] RE: mapserver/PostGIS on Macos X
Puneet Kishor
pkishor at geoanalytics.com
Mon Jan 20 10:13:02 EST 2003
Bill,
Here is the state of my explorations --
I have always been able to build all the Mapserver versions I have tried
(3.4 through 3.6.4) with Perl/Mapscript support.
I have never been able to run PHP/Mapscript successfully. For the longest
time the problem was with PHP on MacOS X -- dynamically loaded libraries
were not possible. Now, with PHP 4.3.0 on, dls are possible, but I am unable
to build PHP/Mapscript (see error messages below at the end of this
message).
I have never had any problem with MySQL and Perl:DBD:mysql, so I am a happy
camper as far as that goes.
I have had no problems with PgSQL itself, but have not built PostGIS.
To others on this mailing list and using MacOS X -- if you are interested, I
would propose our own mailing list (not really a hosted mailing list, but
just a bunch of email addresses we can cc our emails to sharing our
experiences with Mapserver on MacOS X). Eventually, I would like to see a
binary build of Mapserver in the form of a double-clickable package. If
interested, please drop me an email.
Thanks.
> -----Original Message-----
> From: wheatonw at duke.edu [mailto:wheatonw at duke.edu]
> Sent: Friday, January 17, 2003 12:08 PM
> To: pkishor at geoanalytics.com
> Subject: mapserver/PostGIS on Macos X
> Puneet--
> You may not remember, but we corresponded briefly early last
> year about
> building MapServer 3.5 on Macos X. I had version 3.4 working, but
> couldn't get 3.5 working (images came out backwards).
> Anyway, I'm about to embark on an effort to build MapServer 3.6.x and
> PostGIS on my ibook and I was wondering if you had tried to compile
> these beasts on Macos 10.1.x or 10.2.x? I've been looking
> every place
> I can think of and can't find any information about
> experiences trying
> to get these two to work together under Macos x. Unless I can find
> someone who says that it just won't work for some reason, I'm
> going to
> go ahead and give it a try. But I just thought I'd see if anyone had
> tried it yet.
> Thanks in advance for any information.
> Bill
details:
gcc 2.95 on OS X 10.2.3 with the latest devtools and Perl 5.6.0
PHP 4.3.0 built as CGI
--with-xml
--with-zlib
--with-mysql
--with-gd
--with-png
--with-jpeg
--with-xml
--enable-wddx
--enable-dbase
--with-regex=system
Mapserver build log:
-I/Users/pkishor/Projects/mapserver/php-4.3.0/TSRM -c -o
mapscript_i.o mapscript_i.c
/Users/pkishor/Projects/mapserver/mapserver-3.6.4/maptemplate.h:16:
warning: `inchesPerUnit' defined but not used
cc: -flat_namespace: linker input file unused since linking not done
cc -o php_mapscript.so php_mapscript_util.o php_mapscript.o
mapscript_i.o -L/Users/pkishor/Projects/mapserver/mapserver-3.6.4
-lmap -ljpeg -L/usr/local/lib -lpng -lz
-L/Users/pkishor/Projects/mapserver/mapserver-3.6.4/../gd-1.8.4 -lgd
-ljpeg -L/usr/local/lib -lpng -lz -ljpeg -lm
/usr/bin/ld: Undefined symbols:
_main
__convert_to_string
__efree
__emalloc
__estrdup
__object_init_ex
__zend_list_find
__zval_copy_ctor
_add_property_resource_ex
_add_property_zval_ex
_convert_to_double
_convert_to_long
_zend_error
_zend_hash_find
_zend_hash_get_current_data_ex
_zend_hash_get_current_key_ex
_zend_hash_internal_pointer_reset_ex
_zend_hash_move_forward_ex
__array_init
__estrndup
__object_init
__zend_list_addref
__zend_list_delete
_add_assoc_string_ex
_add_next_index_long
_add_next_index_string
_add_property_double_ex
_add_property_long_ex
_add_property_string_ex
_php_header
_php_printf
_php_write
_sapi_module
_zend_get_parameters
_zend_hash_index_find
_zend_hash_num_elements
_zend_list_insert
_zend_register_internal_class
_zend_register_list_destructors
_zend_register_list_destructors_ex
_zend_register_long_constant
_zend_wrong_param_count
make[1]: *** [php_mapscript.so] Error 1
