[Mapserver-users] RE: mapserver/PostGIS on Macos X
Zak James
zak-ms at aiya.dhs.org
Mon Jan 20 14:20:48 EST 2003
I've been able to get php/mapscript running under OS X, even with 4.2.x
PHP versions, by manually editing the php/mapscript makefile. When you
configure mapserver and specify php support, the makefile
(./mapscript/php3/Makefile) is not properly set up.
To use a loadable module under OS X, it needs to be packaged as a
Mach-O bundle. This differs from other unix systems and the configure
script doesn't know about it. My Makefile includes the following:
CC = gcc -fPIC
LD = cc -bundle -flat_namespace -undefined suppress
CFLAGS = -O2 -Wall -DCOMPILE_DL=1 -DPHP4
and compiles mapscript ok.
A MacOS mailing list is a good idea since most mapserver users are
probably not interested in these details. Count me in. This information
should probably be updated on the wiki page
(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MacOS) too.
I think an OS X binary package is needed too, but I'm not sure which of
the many mapserver options it should include.
Zak James
On Monday, January 20, 2003, at 10:13 am, Puneet Kishor wrote:
> Bill,
> Here is the state of my explorations --
> I have always been able to build all the Mapserver versions I have
> tried
> (3.4 through 3.6.4) with Perl/Mapscript support.
> I have never been able to run PHP/Mapscript successfully. For the
> longest
> time the problem was with PHP on MacOS X -- dynamically loaded
> libraries
> were not possible. Now, with PHP 4.3.0 on, dls are possible, but I am
> unable
> to build PHP/Mapscript (see error messages below at the end of this
> message).
> I have never had any problem with MySQL and Perl:DBD:mysql, so I am a
> happy
> camper as far as that goes.
> I have had no problems with PgSQL itself, but have not built PostGIS.
> To others on this mailing list and using MacOS X -- if you are
> interested, I
> would propose our own mailing list (not really a hosted mailing list,
> but
> just a bunch of email addresses we can cc our emails to sharing our
> experiences with Mapserver on MacOS X). Eventually, I would like to
> see a
> binary build of Mapserver in the form of a double-clickable package. If
> interested, please drop me an email.
