[Mapserver-users] ms 3.6.3 itemnquery: need FILTER expression for *multiple* values
George Planansky george_planansky at harvard.edu
Tue Jan 21 00:46:32 PST 2003
With mapserver 3.6.3 using itemnquery , how do you set
the FILTER expression to return multiple selected items?
I can only get it to select the first match.
Using the test suite itemquery/case4 example,
LAYER
  NAME county
  DATA county
  STATUS DEFAULT
  TYPE POLYGON
  FILTER "%value%"          # only gets first match of dynamic value list
  #FILTER  /Aitkin|Anoka/   # shows that filter can get multiple static values
  FILTERITEM CTY_NAME
  CLASS
    COLOR 212 212 212
    OUTLINECOLOR 0 0 0
    TEMPLATE case4_template.html
  END
END
from test.html
  <form method="get" action="/cgi-bin/mapserv">
  <input type="hidden" name="map"
      \value="/usr/local/www/docs/mapserver_demos/tests/itemquery/case4.map">
  <input type="hidden" name="mode" value="itemnquery">
  <input type="hidden" name="qlayer" value="county">
  <input type="hidden" name="item" value="cty_name">
  Select one or more: <br>
  <select name="value" size="5" MULTIPLE>
  <option>  Aitkin
  <option>  Anoka
  <option>  Yellow Medicine
  </select>
  <p>
  <input type="submit" value="Go!">
  </form>
Selecting Becker and Beltrami from the above test.html
produces a GET with both Becker and Beltrami values:
  "GET
  /cgi-bin/mapserv?\
  map=%2Fusr%2Flocal%2Fwww%2Fdocs%2Fmapserver_demos%2Ftests%2Fitemquery%2Fcase4.map\
  &mode=itemnquery\
  &qlayer=county\
  &item=cty_name\
  &value=Becker\
  &value=Beltrami\
  HTTP/1.0" 200 1404
But using
  FILTER %value%
only selects the first value "Becker".
How do you get it to use all the selected values ??
thanks
More information about the MapServer-users mailing list
