[Mapserver-users] How to Draw Annotation Layer Last
Hankley, Chip
Chip.Hankley at GASAI.Com
Tue Jan 21 13:47:46 EST 2003
Dan,
try using 'drawLabelCache' from MapScript right before you render your final
image:
$img = $map->draw();
$map->drawLabelCache($img);
$url = $img->saveWebImage(MS_PNG, $map->transparent, $map->interlace, 50);
Chip Hankley
-----Original Message-----
Sent: Tuesday, January 21, 2003 12:30 PM
To: Dan Barron; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] How to Draw Annotation Layer Last
Dan -
That seems very odd. Can you try making the layer TYPE POINT and see if
that changes anything (just a stab in the dark)?
- Ed
Sent: Tuesday, January 21, 2003 1:23 PM
To: Ed McNierney; mapserver-users at lists.gis.umn.edu
Ed,
Thanks for the reply. I have and had tried moving the layer definition to
the beginning and the end of the map file with the same results. I had
figured it to be more php/mapscript related issue, though when I draw the
layer last in php/mapscript I also have the same result - the annotation
layer is drawn under the other layers. Any other ideas?
Thanks,
Dan
At 12:04 PM 1/21/2003 -0500, Ed McNierney wrote:
Dan -
MapServer draws all layers in order in the mapfile from bottom to top - that
is, each layer in turn is drawn on top of all preceding layers. Put your
annotation layer as the last layer in the file.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
Sent: Tuesday, January 21, 2003 11:49 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] How to Draw Annotation Layer Last
Hello,
I have searched through the archives w/o much luck on determining what I am
doing wrong.
I am using MapServer v3.5 and am trying to draw an annotation layer so it is
always the last layer to be drawn and shows on top of all other layers.
Right now it is always drawn under my other layers and is not seen. I also
use PHP/Mapscript to create the maps and have tried to force this layer to
be drawn last, w/o success. Can anyone clue me in on the method to ensure
this layer is always draw last, either via the map file only or via
php/mapscript? Below is the map file entry for the layer and the
php/mapscript snippet.
Thanks!
LAYER
NAME 'credits'
STATUS ON
TRANSFORM false
TYPE annotation
FEATURE
POINTS 5 10 END
TEXT '© www.destinationdive.com'
END
CLASS
LABEL
TYPE truetype
FONT verdana
SIZE 8
ANTIALIAS true
COLOR 0 0 0
POSITION UR
END
END
END
// ~~~ DRAW Credits Layers ~~~
$creditsLayer = $map->getLayerByName( 'credits' );
$creditsLayer->set( 'status', MS_ON );
$creditsLayer->draw( $image );
// ~~~ DRAW the PNG files for map, scalebar, and reference map ~~~
$image_url_PNG=$image->saveWebImage(MS_PNG,1,1,0);
Dan Barron
Principal / Founder
Destination Software LLC - developers of Destination DIVE"
dbarron at ddive.com
http://www.destinationdive.com
(619) 275-5346
