[Mapserver-users] How to Draw Annotation Layer Last
Ed McNierney
ed at topozone.com
Tue Jan 21 13:29:41 EST 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C2C17B.1052EC5D
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Dan -
=20
That seems very odd. Can you try making the layer TYPE POINT and see if =
that changes anything (just a stab in the dark)?=20
=20
- Ed
-----Original Message-----
Sent: Tuesday, January 21, 2003 1:23 PM
To: Ed McNierney; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] How to Draw Annotation Layer Last
Ed,
Thanks for the reply. I have and had tried moving the layer definition =
to the beginning and the end of the map file with the same results. I =
had figured it to be more php/mapscript related issue, though when I =
draw the layer last in php/mapscript I also have the same result - the =
annotation layer is drawn under the other layers. Any other ideas?
Thanks,
Dan
At 12:04 PM 1/21/2003 -0500, Ed McNierney wrote:
Dan -
=20
MapServer draws all layers in order in the mapfile from bottom to top - =
that is, each layer in turn is drawn on top of all preceding layers. =
Put your annotation layer as the last layer in the file.
=20
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242=20
Sent: Tuesday, January 21, 2003 11:49 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] How to Draw Annotation Layer Last
Hello,
I have searched through the archives w/o much luck on determining what I =
am doing wrong. =20
I am using MapServer v3.5 and am trying to draw an annotation layer so =
it is always the last layer to be drawn and shows on top of all other =
layers. Right now it is always drawn under my other layers and is not =
seen. I also use PHP/Mapscript to create the maps and have tried to =
force this layer to be drawn last, w/o success. Can anyone clue me in =
on the method to ensure this layer is always draw last, either via the =
map file only or via php/mapscript? Below is the map file entry for the =
layer and the php/mapscript snippet.
Thanks!
LAYER
NAME 'credits'
STATUS ON
TRANSFORM false
TYPE annotation
FEATURE
POINTS 5 10 END
TEXT '=A9 www.destinationdive.com' <http://www.destinationdive.com' =
/>=20
END
CLASS
LABEL
TYPE truetype
FONT verdana
SIZE 8
ANTIALIAS true
COLOR 0 0 0=20
POSITION UR
END
END
END
// ~~~ DRAW Credits Layers ~~~
$creditsLayer =3D $map->getLayerByName( 'credits' );
$creditsLayer->set( 'status', MS_ON );
$creditsLayer->draw( $image );
// ~~~ DRAW the PNG files for map, scalebar, and reference map ~~~
$image_url_PNG=3D$image->saveWebImage(MS_PNG,1,1,0);
Dan Barron
Principal / Founder
Destination Software LLC - developers of Destination DIVE"
dbarron at ddive.com
http:// <http://www.destinationdive.com/> =
<http://www.destinationdive.com/> www.destinationdive.com
(619) 275-5346
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1126" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D460182618-21012003><FONT face=3DArial color=3D#0000ff =
size=3D2>Dan=20
-</FONT></SPAN></DIV>
size=3D2></FONT></SPAN> </DIV>
size=3D2>That=20
that=20
changes anything (just a stab in the dark)? </FONT></SPAN></DIV>
<DIV><SPAN class=3D460182618-21012003> <FONT =
face=3DArial=20
color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
size=3D2>-----Original Message-----<BR><B>From:</B> Dan Barron=20
[mailto:dbarron at ddive.com]<BR><B>Sent:</B> Tuesday, January 21, 2003 =
1:23=20
PM<BR><B>To:</B> Ed McNierney;=20
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> RE: =
[Mapserver-users] How=20
to Draw Annotation Layer Last<BR><BR></FONT></DIV>Ed,<BR><BR>Thanks =
for the=20
reply. I have and had tried moving the layer definition to the =
beginning=20
and the end of the map file with the same results. I had figured =
it to=20
be more php/mapscript related issue, though when I draw the layer last =
in=20
php/mapscript I also have the same result - the annotation layer is =
drawn=20
under the other layers. Any other=20
ideas?<BR><BR>Thanks,<BR><BR>Dan<BR><BR>At 12:04 PM 1/21/2003 -0500, =
Ed=20
McNierney wrote:<BR>
<BLOCKQUOTE class=3Dcite cite=3D"" type=3D"cite"><FONT face=3Darial =
color=3D#0000ff=20
size=3D2>Dan -</FONT><BR> <BR><FONT face=3Darial =
color=3D#0000ff=20
size=3D2>MapServer draws all layers in order in the mapfile from =
bottom to top=20
- that is, each layer in turn is drawn on top of all preceding =
layers. =20
Put your annotation layer as the last layer in the=20
file.</FONT><BR> <BR> <FONT face=3Darial =
color=3D#0000ff=20
size=3D2>- Ed</FONT><BR><BR><FONT size=3D2>Ed McNierney<BR>President =
and Chief=20
Mapmaker<BR>TopoZone.com / Maps a la carte, Inc.<BR>73 Princeton =
Street,=20
Suite 305<BR>North Chelmsford, MA =
01863<BR>ed at topozone.com<BR>(978)=20
251-4242 <BR></FONT>
<DL>
<DD><FONT face=3Dtahoma size=3D2>-----Original Message-----<BR>
<DD>From:</B> Dan Barron [<A href=3D"mailto:dbarron at ddive.com"=20
eudora=3D"autourl">mailto:dbarron at ddive.com</A>]<BR>
<DD>Sent:</B> Tuesday, January 21, 2003 11:49 AM<BR>
<DD>To:</B> mapserver-users at lists.gis.umn.edu<BR>
<DD>Subject:</B> [Mapserver-users] How to Draw Annotation Layer=20
Last<BR><BR></FONT>
<DD>Hello,<BR><BR>
<DD>I have searched through the archives w/o much luck on =
determining what=20
I am doing wrong. <BR><BR>
<DD>I am using MapServer v3.5 and am trying to draw an annotation =
layer so=20
it is always the last layer to be drawn and shows on top of all =
other=20
layers. Right now it is always drawn under my other layers =
and is=20
not seen. I also use PHP/Mapscript to create the maps and =
have tried=20
to force this layer to be drawn last, w/o success. Can =
anyone clue=20
me in on the method to ensure this layer is always draw last, =
either via=20
the map file only or via php/mapscript? Below is the map =
file entry=20
for the layer and the php/mapscript snippet.<BR><BR>
<DD>Thanks!<BR><BR><BR>
<DD>LAYER<BR>
<DD> NAME 'credits'<BR>
<DD> STATUS ON<BR>
<DD> TRANSFORM false<BR>
<DD> TYPE annotation<BR>
<DD> FEATURE<BR>
<DD> POINTS 5 10 END<BR>
<DD> TEXT '=A9 <A =
href=3D"http://www.destinationdive.com' /"=20
eudora=3D"autourl">www.destinationdive.com' </A><BR>
<DD> END<BR>
<DD> CLASS<BR>
<DD> LABEL<BR>
<DD> TYPE truetype<BR>
<DD> FONT verdana<BR>
<DD> SIZE 8<BR>
<DD> ANTIALIAS true<BR>
<DD> COLOR 0 0 0 <BR>
<DD> POSITION UR<BR>
<DD> END<BR>
<DD> END<BR>
<DD>END<BR><BR><BR>
<DD>// ~~~ DRAW Credits Layers ~~~<BR>
<DD>$creditsLayer =3D $map->getLayerByName( 'credits' );<BR>
<DD>$creditsLayer->set( 'status', MS_ON );<BR>
<DD>$creditsLayer->draw( $image );<BR><BR>
<DD>// ~~~ DRAW the PNG files for map, scalebar, and reference map =
~~~<BR>
<DD>$image_url_PNG=3D$image->saveWebImage(MS_PNG,1,1,0);<BR><BR><BR>
<DD>Dan Barron<BR></B>
<DD>Principal / Founder<BR>
<DD>Destination Software LLC - developers of Destination =
DIVE"<BR></B>
<DD><FONT color=3D#0000ff>dbarron at ddive.com<BR></U></FONT>
<DD><A href=3D"http://www.destinationdive.com/"=20
eudora=3D"autourl">http://</A><A =
eudora=3D"autourl"><FONT=20
color=3D#0000ff>www.destinationdive.com</A><BR></U></FONT>
<DD>(619) =
275-5346<BR></DD></DL></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C2C17B.1052EC5D--
