[Mapserver-users] How to Draw Annotation Layer Last
Dan Barron
dbarron at ddive.com
Tue Jan 21 13:22:31 EST 2003
--=====================_923578==.ALT
Content-Type: text/plain; charset="iso-8859-1"; format=flowed
Content-Transfer-Encoding: quoted-printable
Ed,
Thanks for the reply. I have and had tried moving the layer definition to=
=20
the beginning and the end of the map file with the same results. I had=20
figured it to be more php/mapscript related issue, though when I draw the=20
layer last in php/mapscript I also have the same result - the annotation=20
layer is drawn under the other layers. Any other ideas?
Thanks,
Dan
At 12:04 PM 1/21/2003 -0500, Ed McNierney wrote:
>Dan -
>MapServer draws all layers in order in the mapfile from bottom to top -=20
>that is, each layer in turn is drawn on top of all preceding layers. Put=
=20
>your annotation layer as the last layer in the file.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: Dan Barron [mailto:dbarron at ddive.com]
>Sent: Tuesday, January 21, 2003 11:49 AM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] How to Draw Annotation Layer Last
>Hello,
>I have searched through the archives w/o much luck on determining what I=20
>am doing wrong.
>I am using MapServer v3.5 and am trying to draw an annotation layer so it=
=20
>is always the last layer to be drawn and shows on top of all other=20
>layers. Right now it is always drawn under my other layers and is not=20
>seen. I also use PHP/Mapscript to create the maps and have tried to force=
=20
>this layer to be drawn last, w/o success. Can anyone clue me in on the=20
>method to ensure this layer is always draw last, either via the map file=20
>only or via php/mapscript? Below is the map file entry for the layer and=
=20
>the php/mapscript snippet.
>Thanks!
>LAYER
> NAME 'credits'
> STATUS ON
> TRANSFORM false
> TYPE annotation
> FEATURE
> POINTS 5 10 END
> TEXT '=A9 www.destinationdive.com'
> END
> CLASS
> LABEL
> TYPE truetype
> FONT verdana
> SIZE 8
> ANTIALIAS true
> COLOR 0 0 0
> POSITION UR
> END
> END
>END
>// ~~~ DRAW Credits Layers ~~~
>$creditsLayer =3D $map->getLayerByName( 'credits' );
>$creditsLayer->set( 'status', MS_ON );
>$creditsLayer->draw( $image );
>// ~~~ DRAW the PNG files for map, scalebar, and reference map ~~~
>$image_url_PNG=3D$image->saveWebImage(MS_PNG,1,1,0);
>Dan Barron
>Principal / Founder
>Destination Software LLC - developers of Destination DIVE"
>http://www.destinationdive.com
>(619) 275-5346
Content-Type: text/html; charset="iso-8859-1"
<html>
<body>
Ed,<br><br>
definition to the beginning and the end of the map file with the same
results. I had figured it to be more php/mapscript related issue,
though when I draw the layer last in php/mapscript I also have the same
result - the annotation layer is drawn under the other layers. Any
other ideas?<br><br>
Thanks,<br><br>
Dan<br><br>
At 12:04 PM 1/21/2003 -0500, Ed McNierney wrote:<br>
<blockquote type=3Dcite class=3Dcite cite><font face=3D"arial" size=3D2 colo=
r=3D"#0000FF">Dan
-</font><br>
<br>
<font face=3D"arial" size=3D2 color=3D"#0000FF">MapServer draws all layers i=
n
order in the mapfile from bottom to top - that is, each layer in turn is
drawn on top of all preceding layers. Put your annotation layer as
the last layer in the file.</font><br>
<br>
<font face=3D"arial" size=3D2 color=3D"#0000FF">-
Ed</font><br><br>
<font size=3D2>Ed McNierney<br>
President and Chief Mapmaker<br>
TopoZone.com / Maps a la carte, Inc.<br>
73 Princeton Street, Suite 305<br>
North Chelmsford, MA 01863<br>
ed at topozone.com<br>
(978) 251-4242 <br>
</font>
<dl>
<dd><font face=3D"tahoma" size=3D2>-----Original Message-----<br>
<dd>From:</b> Dan Barron
[<a href=3D"mailto:dbarron at ddive.com"=
eudora=3D"autourl">mailto:dbarron at ddive.com</a>]<br>
<dd>Sent:</b> Tuesday, January 21, 2003 11:49 AM<br>
<dd>To:</b> mapserver-users at lists.gis.umn.edu<br>
<dd>Subject:</b> [Mapserver-users] How to Draw Annotation Layer
Last<br><br>
</font>
<dd>Hello,<br><br>
<dd>I have searched through the archives w/o much luck on determining
what I am doing wrong. <br><br>
<dd>I am using MapServer v3.5 and am trying to draw an annotation layer
so it is always the last layer to be drawn and shows on top of all other
not seen. I also use PHP/Mapscript to create the maps and have
tried to force this layer to be drawn last, w/o success. Can anyone
clue me in on the method to ensure this layer is always draw last, either
via the map file only or via php/mapscript? Below is the map file
entry for the layer and the php/mapscript snippet.<br><br>
<dd>Thanks!<br><br>
<br>
<dd>LAYER<br>
<dd> NAME 'credits'<br>
<dd> STATUS ON<br>
<dd> TRANSFORM false<br>
<dd> TYPE annotation<br>
<dd> FEATURE<br>
<dd> POINTS 5 10 END<br>
<dd> TEXT '=A9
<a href=3D"http://www.destinationdive.com'=A0/" eudora=3D"autourl">www.desti=
nationdive.com'
</a> <br>
<dd> END<br>
<dd> CLASS<br>
<dd> LABEL<br>
<dd> TYPE truetype<br>
<dd> FONT verdana<br>
<dd> SIZE 8<br>
<dd> ANTIALIAS true<br>
<dd> COLOR 0 0 0 <br>
<dd> POSITION UR<br>
<dd> END<br>
<dd> END<br>
<dd>END<br><br>
<br>
<dd>// ~~~ DRAW Credits Layers ~~~<br>
<dd>$creditsLayer =3D $map->getLayerByName( 'credits' );<br>
<dd>$creditsLayer->set( 'status', MS_ON );<br>
<dd>$creditsLayer->draw( $image );<br><br>
<dd>// ~~~ DRAW the PNG files for map, scalebar, and reference map
~~~<br>
<dd>$image_url_PNG=3D$image->saveWebImage(MS_PNG,1,1,0);<br><br>
<br>
<dd>Dan Barron<br>
</b>
<dd>Principal / Founder<br>
<dd>Destination Software LLC - developers of Destination DIVE"<br>
</b>
<dd><font color=3D"#0000FF">dbarron at ddive.com<br>
</u></font>
<dd><a href=3D"http://www.destinationdive.com/"=
eudora=3D"autourl">http://</a><a href=3D"http://www.destinationdive.com/"=
eudora=3D"autourl"><font color=3D"#0000FF">www.destinationdive.com</a><br>
</u></font>
<dd>(619) 275-5346<br>
</dl></blockquote></body>
</html>
--=====================_923578==.ALT--
