[Mapserver-users] Raster Projection
Ed McNierney
ed at topozone.com
Thu Jan 23 11:48:11 PST 2003
Randy -
If you're using GDAL for raster support (rather than the native GeoTIFF support) you can indeed reproject rasters on the fly. I do this all the time and (within reason) it works just fine.
Most likely suspect: You're not using GDAL
Next most likely suspect: Your AEA and UTM projection specs don't match correctly
Can you post the coordinate and projection specs for both the UTM and the AEA files?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Thursday, January 23, 2003 2:38 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Raster Projection
Hi List
I have some orthophotos in geotiff format. Some are in
albers equal area and some are UTM, projection. H have
been trying to reproject on the fly, but i cannot seem
to get it to work. The map projection is UTM so i do
not have a problem with the orthos that are already in
UTM, but cannot get the AEA orthos to load.
Been reading the list, and seen that raster layers are
used as is and cannot be reprojected on the fly. Is
this correct?
Is it possible to use shape tile index on the
orthophotos, and reproject the shape file? I thought
someone may have tried, if not i'll give it a try
today.
Cheers
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
