[Mapserver-users] GD 2.x install problem
Brian Clark
brclark at usgs.gov
Thu Jan 23 20:56:07 EST 2003
Thanks,
That seemed to work for GD. Now for Mapserver 3.6.4...(sorry to keep
bugging)
tail of make using:
configure --without-tiff --with-proj=/usr/local/lib --with-gdal
--with-wmsclient
renders:
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/include
-I/usr/local/lib -I/usr/local/include mapfile.c -o mapfile.o
mapfile.c: In function `getSymbol':
mapfile.c:154: `__builtin_va_alist' undeclared (first use in this function)
mapfile.c:154: (Each undeclared identifier is reported only once
mapfile.c:154: for each function it appears in.)
mapfile.c:156: warning: implicit declaration of function
`__builtin_va_arg_incr'
mapfile.c:149: warning: `argp' might be used uninitialized in this function
mapfile.c: In function `msLoadProjectionString':
mapfile.c:619: warning: subscript has type `char'
make: *** [mapfile.o] Error 1
Something obvious?
-Brain
Frank Warmerdam wrote:
> Brian wrote:
>> Hey all,
>> We've attempted the upgrade to GD 2.0.11, but initially ran into
>> problems
>> missing jconfig.h, jmorecfg.h, jpeglib.h, jerror.h. Re-directed the
>> path in the Makefile, then ran into problems missing xpm.h.
>> Is this needed? configured --without-xpm, but install gave:
>> ./libtool[4761]: ranlib: not found
>> *** Error code 127
>> make: Fatal error: Command failed for target `install-libLTLIBRARIES'
>> Current working directory /MAPSERVER/GD/gd-2.0.11
>> *** Error code 1
>> make: Fatal error: Command failed for target `install-am'
>> *** Error code 1
>> make: Fatal error: Command failed for target `install-recursive'
>> # exit
> Brian,
> I would suggest trying "make RANLIB=/bin/true". I would have thought the
> configure script would have checked on stuff like libxpm and libjpeg
> being
> available. I think the libgd configure logic is pretty new. Perhaps we
> should submit an error to the maintainer.
> Best regards,
