[Mapserver-users] GD 2.x install problem
Brian Clark
brclark at usgs.gov
Thu Jan 23 19:52:03 EST 2003
Hey all,
We've attempted the upgrade to GD 2.0.11, but initially ran into problems
missing jconfig.h, jmorecfg.h, jpeglib.h, jerror.h.
Re-directed the path in the Makefile, then ran into problems missing xpm.h.
Is this needed? configured --without-xpm, but install gave:
./libtool[4761]: ranlib: not found
*** Error code 127
make: Fatal error: Command failed for target `install-libLTLIBRARIES'
Current working directory /MAPSERVER/GD/gd-2.0.11
*** Error code 1
make: Fatal error: Command failed for target `install-am'
*** Error code 1
make: Fatal error: Command failed for target `install-recursive'
# exit
GD 1.8.4 built without incident.
OS is Solaris 6.
Ideas?
ThaADVANCEnks
-Brian
