[Mapserver-users] little map in a big box
    Ed McNierney
    ed at topozone.com
    Fri Jan 24 13:13:08 PST 2003
Chris -
The EXTENT statement is
	EXTENT minx miny maxx maxy
and you've got
	EXTENT minx maxx miny maxy
so you're defining the X extent of your map to be 462228 to 4082000 (big!) and the Y extent to be equally big, so your map data occupies only a tiny bit of it.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Chris Black [mailto:cblack at CalAcademy.Org]
Sent: Friday, January 24, 2003 4:03 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] little map in a big box
I'm just getting started with MapServer, and I'm having problems
displaying a PNG file.
The visible image of the map takes up only a tiny, postage-stamp-sized
area of the total
image, most of which is white space.  I looked on the list archive, and
saw a similar
problem diagnosed as inconsistent use of units, but I really think I got
all of that
right, with everything in meters -- then redid it with everything in DD,
and got the same
problem, only my visible map image was even smaller.  I got the bounding
coordinates from
the theme properties of an ArcView layer using the same image, the image
size from viewing
the PNG in a Netscape window and reading the document title above the
menu bar (i.e.
pixel as (xmin -
xmax)/721 and similarly for the y dimension.  I'll attach my .map and
.wld files (the version in meters) and hope
someone can help.
ecoatlas.map:
------------------ cut here ----------------------
NAME CALCTYEX1
EXTENT 462228 631000 4082000 4303000
SIZE 721 640
UNITS METERS
SHAPEPATH "C:\inetpub\wwwroot\sfbay\data\"
LAYER
    data "c:\inetpub\wwwroot\sfbay\data\baymap.png"
    NAME "bayraster"
    STATUS DEFAULT
    TYPE RASTER
END # LAYER
END # FILE
baymap.wld:
234
0
0
345
462228
4303000
Many thanks for any help you can offer.
-- Chris Black
California Academy of Sciences
cblack at calacademy.org
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
