[Mapserver-users] FAQ Question
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 27 18:32:26 EST 2003
Sam Gooding wrote:
> I recompiled the PROJ4 libraries using the following commands and
> received no errors:
> ./configure --prefix=/home/sgoody/install
> make install
Sam,
I trust you did a make clean before the make install, right? When
compiling PROJ.4 (specifically src/pj_open_lib.c) was there a
"-DPROJ_LIB=..." on the compile command line? Did it point to the
directory where the epsg translation file got installed?
> Then I proceeded to recompile mapserv using the following commands and
> also received no errors:
> ./configure --with-jpeg --with-gd --with-freetype
> --enable-force-freetype1 --with-zlib --with-png --with-tiff
> --with-proj=/home/sgoody/install
> --with-wmsclient=/home/sgoody/install/bin --enable-runpath
Note you don't have to recompile MapServer when fiddling with the
PROJ.4 installation.
I would suggest verifying the finding of the EPSG translation file with
the PROJ.4 commandline program.
eg.
warmerda at gdal2200[137]% cs2cs +init=epsg:4121 +to +init=epsg:4326
0 0
0d0'2.419"E 0d0'8.03"N -199.865
I would add that errno=13 is apparently EACCESS indicating a permissions
problem, not that the file doesn't exist. Perhaps whatever user your
mapserver/apache runs as (nobody?) does not have read/execute permissions
down to the directory and files in question?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
