[Mapserver-users] FAQ Question
Sam Gooding
samgoody at softhome.net
Mon Jan 27 17:29:05 EST 2003
At 4:30 PM -0500 1/27/03, Daniel Morissette wrote:
>Sam Gooding wrote:
>> (http://mapserver.gis.umn.edu/doc/mdp-howto-template.html#d45e407)
>> The response says that the "epsg" projection definition file file
>> must be installed and be in the right location,
>> '/usr/local/share/proj/'. I do not have root access however, and so
>> I installed PROJ4 to a directory in my home directory
>> (/home/sgoody/install).
>> What I would like to know is, is there any way for me to fix this
>> issue without having my administrator configure and compile mapserv
>> for me?
>Yes, you can configure PROJ4 using "--prefix=/home/sgoody/install" and
>then when you 'make install' to install PROJ4 the epsg file will end up
>in /home/sgoody/install/share/epsg. Then relink your MapServer using
>the new PROJ4 library and it should find the epsg and other support
>files.
>Another option if you don't want to recompile would be to set the
>PROJ_LIB environment variable I think... but I'm not sure whether this
>environment variable works on Unix. You may have to do some research to
>find out more about this one.
I recompiled the PROJ4 libraries using the following commands and
received no errors:
./configure --prefix=/home/sgoody/install
make install
Then I proceeded to recompile mapserv using the following commands
and also received no errors:
./configure --with-jpeg --with-gd --with-freetype
--enable-force-freetype1 --with-zlib --with-png --with-tiff
--with-proj=/home/sgoody/install
--with-wmsclient=/home/sgoody/install/bin --enable-runpath
make all
However when I try to use the WMS client I still receive the following error:
msProcessProjection(): no system list, errno:13
Thanks.
>Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
