[Mapserver-users] switching layers when zooming
Agneta Schick
schick at sdac.hannover.bgr.de
Tue Jan 28 05:51:28 EST 2003
Hello,
As long as I was only using only one layer I thought I knew what I was doing.
Apparently not... I want to show a layer (1:1000000) and after zooming
below 1:250000 switch to a different layer.
My solution is define two layers with the same name but different MINSCALE,
MAXSCALE:
LAYER
NAME relief
DATA graul0.tif
TYPE RASTER
MAXSCALE 5000000
MINSCALE 250000
STATUS DEFAULT
END
LAYER
NAME relief
TILEINDEX index200.shp
TILEITEM "dtk200"
TYPE RASTER
MAXSCALE 250000
STATUS DEFAULT
END
MapScript:
my $layer = $map->getLayerByName('relief');
$layer->draw($map, $img);
I expected Mapserver to interpret $map->{scale} and show the appropriate
map. My result: after zooming below 250000 my layer is empty.
Each if the two layers are ok as a single layer and I've checked the contents of
$map->{scale} so that's not the problem.
Is my whole assumption wrong?
Thank you for your help.
Agneta Schick
Agneta Schick
Bundesanstalt fuer Geowissenschaften und Rohstoffe
Federal Institute for Geosciences and Natural Resources
Stilleweg 2
D- 30655 Hannover Tel.: +49 511 643 3136
GERMANY FAX.: +49 511 643 3663
schick at sdac.hannover.bgr.de http://www.seismologie.bgr.de
