[Mapserver-users] python mapscript install 3.7
Norman
Norman
Wed Jan 29 13:01:04 EST 2003
Michael Schulz writes:
> i have a problem when trying to compile mapserver 3.7 / mapscript for
> python (from the nightly.tar.gz). With the newly included setup.py
> everything works very smooth, mapserver has compiled fine, mapscript
> compilation with some warnings, but when i try to import mapscript in
> python i get this error:
> Python 2.1.2 (#11, Jul 11 2002, 15:03:40)
> >>> import mapscript
> Traceback (most recent call last):
> File "<stdin>", line 1, in ?
> File "/usr/local/lib/python2.1/site-packages/mapscript.py", line 4, in
> import _mapscript
> ImportError: undefined symbol: msAddColor
> Hmm, is this related to the change from mapObj.addColor() to setRGB()?
FYI
I have to make the following changes to mapscript.i
inorder to get a working Python mapscript from the
CVS sources
I have needed to do this for a while
Below I believe
int contrain(rectObj *bounds, double overlay) {
return msConstrainRect(bounds,self, overlay);
should be
int contsrain(rectObj *bounds, double overlay) {
return msConstrainExtent(bounds,self, overlay);
Not sure about the others
Norman
$ cvs diff -cw mapscript.i
Index: mapscript.i
RCS file: /data2/cvsroot/mapserver/mapscript/mapscript.i,v
retrieving revision 1.90
diff -c -w -r1.90 mapscript.i
*** mapscript.i 27 Jan 2003 22:38:42 -0000 1.90
--- mapscript.i 29 Jan 2003 17:46:27 -0000
*** 102,110 ****
return NULL;
! int addColor(int r, int g, int b) {
! return msAddColor(self, r, g, b);
int getSymbolByName(char *name) {
return msGetSymbolIndex(&self->symbolset, name);
--- 102,110 ----
return NULL;
! // int addColor(int r, int g, int b) {
! // return msAddColor(self, r, g, b);
*** 136,146 ****
! if (MS_DRIVER_GD(self->outputformat))
! if(msLoadPalette(image->img.gd, &(self->palette), self->imagecolor) == -1)
! return NULL;
self->cellsize = msAdjustExtent(&(self->extent), self->width, self->height);
status = msCalculateScale(self->extent, self->units, self->width, self->height, self->resolution, &self->scale);
if(status != MS_SUCCESS) return NULL;
--- 136,146 ----
! // if (MS_DRIVER_GD(self->outputformat))
! // if(msLoadPalette(image->img.gd, &(self->palette), self->imagecolor) == -1)
! // return NULL;
*** 754,762 ****
return msAdjustExtent(self, width, height);
! int contrain(rectObj *bounds, double overlay) {
! return msConstrainRect(bounds,self, overlay);
int draw(mapObj *map, layerObj *layer, imageObj *image, int classindex, char *text) {
shapeObj shape;
--- 754,762 ----
! // int contrain(rectObj *bounds, double overlay) {
! // return msConstrainRect(bounds,self, overlay);
shapeObj shape;
