[Mapserver-users] python mapscript install 3.7
Michael Schulz
mschulz at webgis.de
Thu Jan 30 03:42:03 EST 2003
thanks, Sean and Norman, this did it and now it is working - nearly. I ran into trouble with the gdal library, because i
am using MS 3.6.3 with php-mapscript on the same machine, which was compiled with gdal117. After installing gdal118
php-mapscript363 wasn't working anymore (well, some of it wasn't working, especially maplab), then i reinstalled gdal117:
php-mapscript worked again, but of course python mapscript 37 couldn't be imported anymore. So my question is now, how
would you solve this problem? recompile MS363 with gdal118? find a way to have both installed (how could this be done?)?
Thanks, Michael
> FYI
> I have to make the following changes to mapscript.i
> inorder to get a working Python mapscript from the
> CVS sources
> I have needed to do this for a while
> Below I believe
> int contrain(rectObj *bounds, double overlay) {
> return msConstrainRect(bounds,self, overlay);
> should be
> int contsrain(rectObj *bounds, double overlay) {
> return msConstrainExtent(bounds,self, overlay);
> Not sure about the others
> Norman
> $ cvs diff -cw mapscript.i
> Index: mapscript.i
> RCS file: /data2/cvsroot/mapserver/mapscript/mapscript.i,v
> retrieving revision 1.90
> diff -c -w -r1.90 mapscript.i
> *** mapscript.i 27 Jan 2003 22:38:42 -0000 1.90
> --- mapscript.i 29 Jan 2003 17:46:27 -0000
> *** 102,110 ****
> return NULL;
> ! int addColor(int r, int g, int b) {
> ! return msAddColor(self, r, g, b);
> int getSymbolByName(char *name) {
> return msGetSymbolIndex(&self->symbolset, name);
> --- 102,110 ----
> return NULL;
> ! // int addColor(int r, int g, int b) {
> ! // return msAddColor(self, r, g, b);
> *** 136,146 ****
> ! if (MS_DRIVER_GD(self->outputformat))
> ! if(msLoadPalette(image->img.gd, &(self->palette), self->imagecolor) == -1)
> ! return NULL;
> self->cellsize = msAdjustExtent(&(self->extent), self->width, self->height);
> status = msCalculateScale(self->extent, self->units, self->width, self->height, self->resolution, &self->scale);
> if(status != MS_SUCCESS) return NULL;
> --- 136,146 ----
> ! // if (MS_DRIVER_GD(self->outputformat))
> ! // if(msLoadPalette(image->img.gd, &(self->palette), self->imagecolor) == -1)
> ! // return NULL;
> *** 754,762 ****
> return msAdjustExtent(self, width, height);
> ! int contrain(rectObj *bounds, double overlay) {
> ! return msConstrainRect(bounds,self, overlay);
> int draw(mapObj *map, layerObj *layer, imageObj *image, int classindex, char *text) {
> shapeObj shape;
> --- 754,762 ----
> ! // int contrain(rectObj *bounds, double overlay) {
> ! // return msConstrainRect(bounds,self, overlay);
> shapeObj shape;
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
