[Mapserver-users] error compiling --with-pdf
Daniel Morissette
morissette at dmsolutions.ca
Wed Jan 29 20:50:14 EST 2003
Dylan Keon wrote:
> Here's the PDF section of the Makefile (I changed -lPDF to -lpdf, and
> added mappdf.o):
> PDF_INC= -I/opt/apps/include
> PDF_LIB= -L/opt/apps/lib -lpdf
> PDF= -DUSE_PDF
> PDF_OBJ= mappdf.o
There were a few issues with the configure script when you were passing
an explicit path to the --with-pdf switch. I fixed them in the 3.7 CVS
and you should (hopefully) not have to edit the makefile any more.
> c++ -shared -o php_mapscript.so
> php_mapscript_util.o php_mapscript.o mapscript_i.o
> -L/opt/src/ms_cvs_01-28-03 -lmap -L/usr/lib -lcurl -lz -ldl -lz
> -L/opt/apps/lib -lpq -L/opt/src/gdal-1.1.8 -lgdal.1.1 -L/opt/apps
> -L/opt/apps/lib -ljpeg -L/opt/apps -L/opt/apps/lib -lpng -L/opt/apps
> -L/opt/apps -lz -lm -ldl -L/usr/local/lib -lm -lpthread
> -L/opt/apps/lib -lproj -L/opt/apps/lib -ljpeg -L/opt/apps/lib
> -lfreetype -L/opt/apps/lib -lpng -L/opt/apps/lib -lz -L/usr/X11R6/lib
> -lXpm -lX11 -L/opt/apps/lib -lPDF -L/opt/apps/lib -lgd -L/opt/apps/lib
> -ljpeg -L/opt/apps/lib -lfreetype -L/opt/apps/lib -lpng -L/opt/apps/lib
> -lz -L/usr/X11R6/lib -lXpm -lX11 -L/opt/apps/lib -ljpeg -lm
> /opt/src/gdal-1.1.8/ogr/ogrsf_frmts/ogrsf_frmts.a
> /opt/src/gdal-1.1.8/ogr/ogr.a /opt/src/gdal-1.1.8/ogr/../port/cpl.a
> /usr/bin/ld: cannot find -lPDF
> collect2: ld returned 1 exit status
> make[1]: *** [php_mapscript.so] Error 1
Notice that the link command and the error message still refer to -lPDF
in uppercase even though you edited the main makefile to use -lpdf.
This is probably because you didn't edit the mapscript/php3/Makefile to
apply the same change.
Anyway, please get the latest configure and Makefile from CVS and give
them a try. Your problems will probably go away.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
