[Mapserver-users] error compiling --with-pdf
Dylan Keon
keon at nacse.org
Thu Jan 30 01:39:26 EST 2003
Daniel Morissette wrote:
> There were a few issues with the configure script when you were passing
> an explicit path to the --with-pdf switch. I fixed them in the 3.7 CVS
> and you should (hopefully) not have to edit the makefile any more.
Thanks. I grabbed the latest CVS and it compiled just fine using
--with-pdf=/opt/apps. Didn't have to edit the Makefiles.
> Notice that the link command and the error message still refer to -lPDF
> in uppercase even though you edited the main makefile to use -lpdf.
> This is probably because you didn't edit the mapscript/php3/Makefile to
> apply the same change.
That was my problem. I forgot about the mapscript/php3/Makefile :-)
Thanks,
Dylan
