[Mapserver-users] Memory Leak?
Lowell Filak lfilak at medinaco.org
Fri Jan 31 05:38:51 PST 2003
Shot in the dark, but is there a possibility that after a map is created the mapObj is not being undef/closed/destroyed and that is the leak your seeing?
Lowell F.
The following message was sent by "Juanse" <georef at tie.cl> on Fri, 31 Jan 2003 10:27:27 -0300.
> Hi everyone
> We have build this "mapmaker machine" scripting mapserver with php.
> The mapmaker machine need to do 2322 maps, comprised of a.- the map, b the
> legend, c.- the reference map.
> The application created the regional map (10 layers, 2 with thematic clases)
> then centers over the specified spot (center of each of 2322 polygons in one
> of the layers stored in postgresql).
> Then mapserver render the 3 images (png) and stores the *.png files in a
> file and the file names in the speceified columns in the postgresql table.
> if one check the process (top) the memory fill up after 90 spots, and then
> the whole machine work very slowly (20 maps per night). At this speed we
> need more than a 100 days to finish?
> Is there any command to free mapserver from memory? Does mapserver have any
> know memory leaks?
> Juanse
> temuko-Chile
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.445 / Virus Database: 250 - Release Date: 21/01/03
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
