[Mapserver-users] Problem with Perl Mapscript
AMC Story
s9646183 at sms.ed.ac.uk
Thu Jul 3 07:41:52 EDT 2003
Hi everyone,
Following my question about using JavaScript/MapScript to develop the standard
MapServer interface, I've now decided to try to use both, and have got the Perl
MapScript module working on our apache server.
My problem is that most of the documentation and examples are for PHP
MapScript. Having only a list of constructors/methods etc for each object type
is helpful to a point, but this doesn't tell me how I should be putting them
together to get something to actually work! I've been trying to convert the
PHP MapScript by Example HOWTO into perl, using Steve Lime's mapquakes.pl as a
guide.
My first problem is that perl mapscript doesn't seem to have a direct
equivalent of the saveWebImage method. Is this correct? In the absence of
such a method, I've been trying to use the saveImage method, but here I seem to
be running into problems. If you look at the way I've called the method (see
code below), then maybe you could suggest what I'm doing wrong.
In the first case (ie. using mapscript::msSaveImage(...)), I get the error
message "Type error in argument 1 of msSaveImage. Expected _p_gdImagePtr..."
when I run the program at the command line. In the second case, using $image-
>saveImage(..), I get the following usage message "Usage: imageObj_saveImage
(self,filename,type,transparent,interlace,quality);". This has confused me
because this isn't the argument list given in the documentation.
If anyone has some simple, step by step examples of how to build up
applications using Perl MapScript I'd be really interested in having a look.
Many thanks,
Ali
#!/usr/local/bin/perl -w
#playing around with mapscript
#use mapscript;
use CGI qw(:standard);
use mapscript;
$cgi = new CGI;
$map_file = "/usr/local/apache/local-bin/s9646183/mapscript/quakes.map";
$image_path = "/usr/local/apache/htdocs/tmp/";
$image_url = "/tmp/";
$image_id = $$ . time() . ".png";
$map = new mapscript::mapObj($map_file);
$image = $map->prepareImage();
$layer = $map->getLayerByName('countries');
$layer->draw($map, $image);
mapscript::msSaveImage($image, $image_path.$image_id, $map->{imagetype}, $map->
{transparent}, $map->{interlace}, $map->{imagequality});
#$image->saveImage($image, $image_path.$image_id, $mapscript::MS_PNG, $map->
print $cgi->header();
print $cgi->start_html(-title=>'Map 1: Perl Mapscript Test');
print "<p>This is just a test</p>";
print "<center><input type=\"image\" name=\"map\" src=\"". $image_url .
$image_id ."\"><br>";
print $cgi->end_html();
