[Mapserver-users] Layer Problem
Vincent Schut
schut at sarvision.com
Thu Jul 3 10:36:37 EDT 2003
Hmm
should have worked, but to be sure: first type 'make clean' in the mapserver
source dir, then ./configure --your-options and make. Then you definitely
have a new mapserv exe which has used the new map.h file.
Cheers,
Vincent.
On Thursday 03 July 2003 15:59, James Anderson wrote:
> Hi,
> I am having issues with the compilation.
> I changed the MS_MAXLAYERS define from 100 to 500 in map.h
> I then did a
> ./configure --with-gd --with-proj --with-gdal=/usr/local/bin/gdal-config
> -- with-ogr
> which seemed to work
> then I did a make
> which also seems to work
> If I understand correctly, it would now have made the mapserv executable
> file in the current directory with the source, and it seems to be doing
> this as the mapserv file gets the current date and time. The problem is
> that when I compare the file to the previously built executabe, they are
> byte identical. Also it does not seem to be accepting more layers. So
> have I changed the value in the right place, am I compiling it correctly ?
> I also have copied the new exe to the cgi-bin where I call it from, but it
> does not really matter, because as I said, they seem to be byte identical.
> You have any ideas as to what I may be doing wrong ? The main issue is
> it still has the too many layer error.
> Regards,
> James.
> ----- Original Message -----
> From: "Paul Spencer" <pagameba at magma.ca>
> To: "James Anderson" <james at danisat.net>
> Cc: <spencer at dmsolutions.ca>; <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, July 03, 2003 2:51 PM
> Subject: Re: [Mapserver-users] Layer Problem
> | no idea. theoretically, this value causes mapserver to pre-allocate
> | sufficient storage for the defined number of layers. Changing this
> | number should change the memory footprint of the executable. I am
> | guessing that the actual data structures are not that large, so you
> | should be able to create thousands of layers if you need to, but it will
> | depend on how much memory you have available for a given process. I'm
> | not sure, but there may be a memory limit imposed by Apache on cgis?
> | I'd suggest that you rebuild with the number you have in mind plus a
> | decent buffer and try it :)
> | Cheers,
> | Paul
> | > Thanks very much. How high do u think I can take it ?
> | > Regards,
> | > James.
> | > Cc: <mapserver-users at lists.gis.umn.edu>
> | > Sent: Thursday, July 03, 2003 1:36 PM
> | > | edit this line in map.h and rebuild mapserver.
> | > | #define MS_MAXLAYERS 100 /* maximum number of layers in a map file */
> | > | Cheers,
> | > | Paul
> | > | > Hi Everybody,
> | > | > I seem to have a big problem ......
> | > | > I am using mapserver on Red Hat 8 Linux.
> | > | > MapServer version 3.6.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ
> | > | > SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> | > | > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> | > | > I have many vector layers and some raster layers too. At the
> | > | > moment
> my
> | > | > map file has over 100 layers in it. My problem is that when I have
> | > | > tried adding some more layers, I get the error
> | > | > msLoadMap(): Unknown identifier. Too many layers defined.
> | > | > Now this is a problem as I need to have all these layers. I got so
> many
> | > | > layers that its too many to count the exact amount. But this is a
> | > | > problem, and my project is going to fail if I cannot find a way to
> get
> | > | > mapserver to support/accept more layers. Can anyone give me an
> idea of
> | > | > what the maximum number of layers is, and how I can go about
> increasing
> | > | > the amount of layers that is supported. I have an idea that I am
> going
> | > | > to have to recompile the mapserver. Please anybody, Please Help
> | > | > Thanks,
> | > | > James.
> | > | Paul Spencer
> | > | Applications and Software Development
> | > | DM Solutions Group Inc.
> | > | http://www.dmsolutions.ca
> | > _______________________________________________
> | > Mapserver-users mailing list
> | > Mapserver-users at lists.gis.umn.edu
> | > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> | Paul Spencer
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
