[Mapserver-users] polygon lable problem
Steve Lime
steve.lime at dnr.state.mn.us
Wed Jul 9 00:43:12 EDT 2003
Can you share the data? Concave layers are generally not a problem.
Polygon labeling uses a technique similar to scanline conversion used to
compute label points so label points are gauranteed to be "in" the
polygon. Could be an issue with clipping, or perhaps the label cache
(you could test that by setting LABELCACHE OFF), but there's no way to
know without the data and an extent that shows the problem.
I'll be out until the 14th but will look at it then. BTW What version
are you using?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Aaron D. Hunt" <hunt at zedxinc.com> 07/08/03 11:37 AM >>>
There is a label item but I am overriding the with a TEXT Cool/Wet in
the class. This is not the first time I have had this problem with
labeling.
----- Original Message -----
To: Aaron D. Hunt ; mapserver-users at lists.gis.umn.edu
Sent: Tuesday, July 08, 2003 12:27 PM
Subject: RE: [Mapserver-users] polygon lable problem
Aaron -
Have you checked the attribute table for the data layer, and are you
SURE that there is indeed a label string for that polygon?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Tuesday, July 08, 2003 12:02 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] polygon lable problem
With the layer below, Mapserver seams to have a problem labeling
concave polygons. If you look at the image link below, there is one
concave polygon in Canada that is not labeled. Is there any way to get
mapserver to label the polygon.
http://wcs.zedxinc.com/dy_images/cold.png
LAYER
NAME weather
TYPE polygon
TRANSPARENCY 60
LABELITEM "COLOR"
DATA ""
STATUS ON
CLASS
NAME "NAM"
COLOR 47 111 111
TEXT Cool/Wet
LABEL
force true
TYPE TRUETYPE
FONT arial
SIZE 12
POSITION cc
ANTIALIAS FALSE
OUTLINECOLOR 255 255 255
COLOR 0 0 0
END
END
END
Aaron D. Hunt
Technical Manager
ZedX Inc.
Voice: 814-357-8490
Fax: 814-357-8499
