[Mapserver-users] preprocessing 24bit Rasterdata
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 9 08:41:09 EDT 2003
Christina Biakowski (CCGIS) wrote:
> Hello,
> since I am still using Mapserver 3.6, I have to convert my rasterdata (24bit
> orthophotos, TIFF) into 8bit.
> Does any of the GDAL-utilities supply this convert-function? I am not very
> familiar with image-formats and properties and searching the gdal-site and
> the mailing-archive did not help to answer my question.
> Or which other tool I could use alternatively to convert my images? (in a
> batch-process, because I have quite a lot images to convert. The image
> processing program I am using does not support the conversion in a batch.)
> Thanks a lot!
> Regards,
> Christina
Christina,
GDAL has a Python script utility called rgb2pct.py that can be used for
compressing a 24bit image to an 8bit pseudo-colored image. It uses "optimal"
colortable selection, and dithering to give the best representation I know
how.
As Vincent mentioned, imagemagick is also very good and is even more flexible
in options. The advantage of GDALs rgb2pct.py is that is preserves any
georeferencing.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
