[Mapserver-users] polygon lable problem
Aaron D. Hunt
hunt at zedxinc.com
Wed Jul 9 12:09:30 EDT 2003
The code worked great, Thank you
----- Original Message -----
To: "Aaron D. Hunt" <hunt at zedxinc.com>; <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, July 09, 2003 4:05 AM
Subject: Re: [Mapserver-users] polygon lable problem
> Aaron,
> I once had the same symptoms so maybe the same problem, which I solved by
> slighly modifying the source code of mapserver. I asked the developers to
add
> this to cvs because it really seemed to improve labeling, but I don't know
if
> they'd done it, and if not, why. Maybe I should file a bug/feature request
on
> this? If one of the developers (Steve, you once mailed that you would
check
> the patch) reads this, could you be so kind to answer this?
> The proposed patch is in a mail thread of the mapserver-dev list. Search
the
> archives of this list for the subject "label centroid alog". You will find
> the patch there, it's quite simple, just a few lines to change. You could
do
> it by hand, just remove the lines that start with a minus sign and add the
> lines with a plus sign :-). Or use 'patch'.
> For me this change was magick: at once all my labels appeared. Hope it
does
> the trick for you too.
> Cheers,
> Vincent.
> On Tuesday 08 July 2003 18:02, Aaron D. Hunt wrote:
> > With the layer below, Mapserver seams to have a problem labeling concave
> > polygons. If you look at the image link below, there is one concave
polygon
> > in Canada that is not labeled. Is there any way to get mapserver to
label
> > the polygon.
> > http://wcs.zedxinc.com/dy images/cold.png
> > LAYER
> > NAME weather
> > TYPE polygon
> > TRANSPARENCY 60
> > LABELITEM "COLOR"
> > DATA ""
> > STATUS ON
> > CLASS
> > NAME "NAM"
> > COLOR 47 111 111
> > TEXT Cool/Wet
> > LABEL
> > force true
> > TYPE TRUETYPE
> > FONT arial
> > SIZE 12
> > POSITION cc
> > ANTIALIAS FALSE
> > OUTLINECOLOR 255 255 255
> > COLOR 0 0 0
> > END
> > END
> > END
> > Aaron D. Hunt
> > Technical Manager
> > ZedX Inc.
> > Voice: 814-357-8490
> > Fax: 814-357-8499
> ______________________________________
> Vincent Schut
> Sarvision B.V.
> Wageningen, The Netherlands
> www.sarvision.com
