[Mapserver-users] polygon lable problem
Daniel Morissette
morissette at dmsolutions.ca
Wed Jul 9 09:16:38 EDT 2003
Vincent Schut wrote:
> Aaron,
> I once had the same symptoms so maybe the same problem, which I solved by
> slighly modifying the source code of mapserver. I asked the developers to add
> this to cvs because it really seemed to improve labeling, but I don't know if
> they'd done it, and if not, why. Maybe I should file a bug/feature request on
> this? If one of the developers (Steve, you once mailed that you would check
> the patch) reads this, could you be so kind to answer this?
Please go ahead and file this in bugzilla to make sure we don't forget.
Also make sure you set the bug Version to 4.0. I could possibly apply it
myself but since Steve knows this code best I would rather let him do it
when he's back in a few days.
Thanks
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
