[Mapserver-users] generate maps in WBMP (for WAP)
Lowell Filak
lfilak at medinaco.org
Thu Jul 10 12:30:45 PDT 2003
Complete shot in the dark.
Did you try setting interlace & transparent to false?
$mapscript::MS_FALSE
Is WBMP supposed to support those options.?
Lowell
The following message was sent by Pedro Salazar
<pedro-b-salazar at ptinovacao.pt> on 10 Jul 2003 19:06:29 +0100.
> > Yes it's possible. GD supports WBMP so it should just be a matter of
> > setting "IMAGETYPE WBMP" in your mapfile. Note that you should take
> > into consideration the fact that WBMP images can have only 2 colors as
> > you design your mapfile.
> I'm using mapscript. If I use:
> print $query->header('image/vnd.wap.wbmp');
> $img->saveImage($tmp_file,$mapscript::MS_WBMP, $map->{transparent},
> $map->{interlace}, 0);
> system("cat $tmp_file");
> Shouldn't this work? ... Well, I have a viewer (wApua for linux) that I
> can see some BMP images converted to WBMP, but the WBMP files generated
> by mapserver I can't see on my viewer!!
> BTW, I used 'image/png' and MS_PNG for PNG images, so I just replace
> this values with the WBMP values above.
> thanks,
> Pedro Salazar
> PS
> PGP:0E129E31D803BC61
More information about the MapServer-users
