[Mapserver-users] Mapserver Bug
Zamil Murji
Zamil.Murji at divestco.com
Tue Jul 15 13:36:22 EDT 2003
I am using mapserv version 4.0 beta 1. At least that is what the mapserv.exe -v said. I dowloaded it from the mapserver homepage.
Thanks
Zamil
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Tuesday, July 15, 2003 11:25 AM
To: Zamil Murji; rjames57 at yahoo.com
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Mapserver Bug
Let's start here. What version are we talking about? There were some
changes (cosmetic, but still changes) in how shapefile access was
managed in 4.0 so if that's the version in question can someone verify
that tiled shapefiles work?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Randy James <rjames57 at yahoo.com> 07/15/03 12:06PM >>>
I'll forward the post to the list, someone else may be able
to help. I think more information on your setup will get
better input from the list.
Cheers
--- Zamil Murji <Zamil.Murji at divestco.com> wrote:
> Yup,
> I can show one layer at a time, but I can't get both on
> at the same time.
> From: Randy James [mailto:rjames57 at yahoo.com]
> Sent: Tuesday, July 15, 2003 10:54 AM
> To: Zamil Murji
> Hi
> Well hmm projection for the layers is correct?
> > the tiled shapefile location column does in fact
> contain
> > the full path to the tiled files. can you think of
> > anything else?
> > Sent: Monday, July 14, 2003 5:02 PM
> > To: Zamil Murji
> > the tiled shapefile location column should contain the
> > full
> > > Hi,
> > > What do you mean by this? Do you mean in the .map
> file
> > or
> > > the actual tiled shapefile location column?
> > > Thanks
> > > Zamil
> > > Sent: Monday, July 14, 2003 4:56 PM
> > > To: Zamil Murji
> > > Hi
> > > Do you have the full path, (rather than relative) in
> > the
> > > location column?
> > > > Hi Randy and company,
> > > > No i don't think i need tileitem because i am using
> > the
> > > > default of 'location'. I repeat that the first
> tiled
> > > > layer shows up but the ones underneath it do not.
> > > > Thanks
> > > > Zamil
> > > > Sent: Monday, July 14, 2003 4:48 PM
> > > > To: Zamil Murji
> > > > Cc: Mapserver-users at lists.gis.umn.edu
> > > > Subject: Re: [Mapserver-users] Mapserver Bug
> > > > Hi
> > > > Looks like you need the TILEITEM in your mapfile
> > > > It is the column that has the location of the tile
> in
> > > it
> > > > Cheers
> > > > > Hi Steve and the rest of the list,
> > > > > I found a bug with regards to mapserver and tiled
> > > > polygon
> > > > > layers. It seems that mapserver only displays the
> > > first
> > > > > tiled polygon layer in the .map file and doesn't
> > show
> > > > the
> > > > > tiled polygon layers below it. All other layers
> > show
> > > up
> > > > > just fine below the first tiled polygon layer.
> > > > > I've attached two images. One with the tile
> county
> > > > layer
> > > > > showing (above the township grid) and another
> with
> > > the
> > > > > township gird showing (above the county layer).
> > > > > Here are the two layer defs, please tell me if
> i'm
> > > > > missing something obvious:
> > > > > LAYER
> > > > > NAME "counties"
> > > > > TILEINDEX us_data/culture/countytileindex
> > > > > STATUS off
> > > > > TYPE POLYGON
> > > > > CLASS
> > > > > OUTLINECOLOR 0 0 0
> > > > > end
> > > > > end
> > > > > LAYER
> > > > > NAME "twp"
> > > > > TILEINDEX us_data/townships/twptileindex
> > > > > STATUS off
> > > > > TYPE POLYGON
> > > > > # MAXSCALE 25
> > > > > CLASS
> > > > > OUTLINECOLOR 183 178 178
> > > > > #OUTLINECOLOR 255 0 0
> > > > > END
> > > > > END
> > > > > Zamil
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > Do you Yahoo!?
> > > > SBC Yahoo! DSL - Now only $29.95 per month!
> > > > http://sbc.yahoo.com
> > > Do you Yahoo!?
> > Do you Yahoo!?
