[Mapserver-users] Mapserver Bug
Zamil Murji
Zamil.Murji at divestco.com
Tue Jul 15 10:56:45 PDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C34AFA.74558F4A
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Let's start again,=20
Here are my mapserv info:
MapServer version 4.0-beta1 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG =
OUTPUT=3DWBMP OUTPUT
=3DPDF OUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE =
SUPPORTS=3DWMS_SERVER SUPPORTS=3DWMS
_CLIENT SUPPORTS=3DWFS_SERVER SUPPORTS=3DWFS_CLIENT INPUT=3DEPPL7 =
INPUT=3DPOSTGIS INPUT=3D
OGR INPUT=3DGDAL INPUT=3DSHAPEFILE
Here is my two layer definitions:
LAYER
# fast file
NAME "counties"
DATA boarders/counties
STATUS off
TYPE POLYGON
MAXSCALE 29
CLASS
OUTLINECOLOR 0 0 0
# COLOR 84 247 168
END
END
...and later on in the mapfile
LAYER
NAME "twp"
TILEINDEX us_data/townships/twptileindex
STATUS off
TYPE POLYGON
MAXSCALE 29
# MINSCALE 25
CLASS
OUTLINECOLOR 183 178 178
#OUTLINECOLOR 255 0 0=20
END
END
If i keep it like this in the .map file then i get image1 (see =
attached), if I switch the two layers around in the .map file then i get =
image2 (see attached). What am i doing wrong. Both are the exact same =
call to mapserv =
(http://10.0.50.131/cgi-bin/mapserv.exe?mode=3Dmap&map=3Dc:\mapfiles/test=
.map&mapext=3D-109.05660+39.20555+-107.00299+41.13418&mapsize=3D723+679&l=
ayers=3Dcounties+twp)
Can you think of anything?
Thanks
Zamil
Thanks
Zamil
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Tuesday, July 15, 2003 11:25 AM
To: Zamil Murji; rjames57 at yahoo.com
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Mapserver Bug
Let's start here. What version are we talking about? There were some
changes (cosmetic, but still changes) in how shapefile access was
managed in 4.0 so if that's the version in question can someone verify
that tiled shapefiles work?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Randy James <rjames57 at yahoo.com> 07/15/03 12:06PM >>>
I'll forward the post to the list, someone else may be able
to help. I think more information on your setup will get
better input from the list.
Cheers
--- Zamil Murji <Zamil.Murji at divestco.com> wrote:
> Yup,=20
> I can show one layer at a time, but I can't get both on
> at the same time.
>=20
> From: Randy James [mailto:rjames57 at yahoo.com]=20
> Sent: Tuesday, July 15, 2003 10:54 AM
> To: Zamil Murji
>=20
>=20
> Hi
>=20
> Well hmm projection for the layers is correct?=20
>=20
> > the tiled shapefile location column does in fact
> contain
> > the full path to the tiled files. can you think of
> > anything else?
> >=20
> > Sent: Monday, July 14, 2003 5:02 PM
> > To: Zamil Murji
> >=20
> >=20
> > the tiled shapefile location column should contain the
> > full
> >=20
> > > Hi,
> > >=20
> > > What do you mean by this? Do you mean in the .map
> file
> > or
> > > the actual tiled shapefile location column?
> > >=20
> > > Thanks
> > > Zamil
> > >=20
> > > Sent: Monday, July 14, 2003 4:56 PM
> > > To: Zamil Murji
> > >=20
> > >=20
> > > Hi
> > >=20
> > > Do you have the full path, (rather than relative) in
> > the
> > > location column?
> > >=20
> > >=20
> > > > Hi Randy and company,
> > > >=20
> > > > No i don't think i need tileitem because i am using
> > the
> > > > default of 'location'. I repeat that the first
> tiled
> > > > layer shows up but the ones underneath it do not.
> > > >=20
> > > > Thanks
> > > > Zamil
> > > >=20
> > > > Sent: Monday, July 14, 2003 4:48 PM
> > > > To: Zamil Murji
> > > > Cc: Mapserver-users at lists.gis.umn.edu=20
> > > > Subject: Re: [Mapserver-users] Mapserver Bug
> > > >=20
> > > >=20
> > > > Hi=20
> > > >=20
> > > > Looks like you need the TILEITEM in your mapfile
> > > >=20
> > > > It is the column that has the location of the tile
> in
> > > it
> > > >=20
> > > > Cheers
> > > >=20
> > > > > Hi Steve and the rest of the list,
> > > > >=20
> > > > > I found a bug with regards to mapserver and tiled
> > > > polygon
> > > > > layers. It seems that mapserver only displays the
> > > first
> > > > > tiled polygon layer in the .map file and doesn't
> > show
> > > > the
> > > > > tiled polygon layers below it. All other layers
> > show
> > > up
> > > > > just fine below the first tiled polygon layer.=20
> > > > >=20
> > > > > I've attached two images. One with the tile
> county
> > > > layer
> > > > > showing (above the township grid) and another
> with
> > > the
> > > > > township gird showing (above the county layer).=20
> > > > > Here are the two layer defs, please tell me if
> i'm
> > > > > missing something obvious:
> > > > > LAYER
> > > > > NAME "counties"
> > > > > TILEINDEX us_data/culture/countytileindex
> > > > > STATUS off
> > > > > TYPE POLYGON
> > > > > CLASS
> > > > > OUTLINECOLOR 0 0 0
> > > > > end
> > > > > end =20
> > > > >=20
> > > > > LAYER
> > > > > NAME "twp"
> > > > > STATUS off
> > > > > TYPE POLYGON
> > > > > # MAXSCALE 25
> > > > > CLASS
> > > > > END
> > > > > END
> > > > >=20
> > > > > Zamil
> > > > >=20
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users=20
> > > >=20
> > > >=20
> > > > Do you Yahoo!?
> > > > SBC Yahoo! DSL - Now only $29.95 per month!
> > > > http://sbc.yahoo.com=20
> > >=20
> > >=20
> > > Do you Yahoo!?
> >=20
> >=20
> > Do you Yahoo!?
>=20
>=20
>=20
Content-Type: image/gif;
name="image1.gif"
Content-Transfer-Encoding: base64
Content-Description: image1.gif
Content-Disposition: attachment;
filename="image1.gif"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name="image2.gif"
Content-Description: image2.gif
filename="image2.gif"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------_=_NextPart_001_01C34AFA.74558F4A--
More information about the MapServer-users
