[Mapserver-users] Using TIGER files
Jeff Hoffmann
jeff at propertykey.com
Thu Jul 17 09:16:31 EDT 2003
woodbri at swoodbridge.com wrote:
> Attri,
> The Tiger/line files are useful for generating the base map and
> extracting the polygons that relate back to the Census statistical
> data. You will have to get the statistical data and relate that to
> the polygons probably using JOIN to relate the polygon to the stats
> and then use LAYER CLASSes to apply graphical (color/style/etc)
> attributes to the polygons.
> This implies that you can find the statistical data on the Census
> website and load it into DBF files or Postgres so you can join it
> with your polygon layer(s).
That's a great message. The only other thing that I can add is that I
have table layouts for both the SF1 and SF3 extracts that can be used to
import that data into PostgreSQL. You can find them at
ftp://ftp.propertykey.com/pub/downloads/misc
They're called sf1.tar.gz & sf3.tar.gz and should work with the data
that you can download from the Census web site -- I don't recall the
specific location off the top of my head, but it shouldn't be hard to
find. Basically, the tables from there get linked to the census blocks
information from the TIGER through a geo file. There's no documentation
in my downloads, but it should be pretty straightforward. All of the
.sql files create the tables and import the data. There's one little
perl script that converts the geo file from fixed-length to
tab-delimited so it can be imported, but all of the rest of the data
files can be imported as is -- if I recall correctly they were comma
delimited, which works fine for PostgreSQL. As mentioned earlier, we
used TIGER2SHP to convert the TIGER files to shape files to get the
census block shape files for use with MapServer -- it's a nice little
utility & i think is well worth the price.
Jeff Hoffmann
PropertyKey.com
