[Mapserver-users] Perl/Library Question
Steve Lehr
lehrs at erau.edu
Thu Jul 17 12:02:06 EDT 2003
I'm trying to see if gd2.x will solve a limitation in old gd 1.3 that when
an irregular shaped polygon is rendered it gets white lines on it
--- | <- problem old gd draws white line here
|--| | <- Another white line here.
|_____|
Ok..
I have the latest version of GD on my box, my question is how do I get perl
to pick up a different library with the USE command.
i.e. use GD; picks up the standard old GD library....I'd like to specify it
to use /installs/gd-2.0.15
Is this possible?
Thanks
Steven Lehr
Visiting Professor
Embry-Riddle Aeronautical University (LB159)
600 S. Clyde Morris Blvd.
Daytona Beach, FL 32114-3900
386-226-7740
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Joe Smith
Sent: Thursday, July 17, 2003 11:05 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Mapscript problems
I have been working with mapserver for a few weeks now without too much
trouble, but I've run into some problems trying to get mapscript to compile.
It runs fine without the --with-php option, but I'm looking to add more
functionality. I'm actually trying to get mapscript compiled in two
places - my local linux box where i do the editing, and on the web server.
It doesn't seem to work on either.
Here's the specs/problem on the local box:
Linux 9, apache 2.0.47, php 4.3.2, mapserver 3.6.6
I know what the problem is ; php isn't compiling with
the --with-regex=system like it should, and I don't know why. I checked
phpinfo and the regex section didn't have anything about system. I compile
php like this:
./configure \
--prefix=/usr/local/www/php \
--with-config-file-path=/usr/local/www/php \
--enable-track-vars \
--enable-force-cgi-redirect \
--with-regex=system \
--with-mysql \
--with-zlib \
--without-ttf
make
make install
cp -p php.ini-recommended /usr/local/www/php/php.ini
I tried removing config.cache like some of the posts suggested (and make
clean), but it did not work. I'm still getting familiar with linux/unix so
I wouldn't really know where to look if it was using some old version of a
file in the compile.
Here's the specs/problem on the web server:
FreeBSD 4.4, apache 1.3.22, php 4.0.6, mapserver 3.6.6
When I try to make mapserver, I get this:
A bunch of undefined references when it gets to php_mapscript.so
"Stop in /usr/home/joe/mapserver/mapscript/php3"
"*** Error code 1"
Here's my configure line for mapserver:
./configure --with-gd=/usr/local --with-php=/usr/local/www/include/php
I do have root access, and apache and php were already running so I don't
want to mess with them if I don't have to, since it's a virtual server (I
could probably recompile php though). Is anyone familar with either of
these problems or have any ideas? Thanks in advance!
Joe
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
