[Mapserver-users] Perl/Library Question
Eric Bridger
eric at gomoos.org
Thu Jul 17 08:53:28 EDT 2003
As usual there are many ways to do it. You need to alter the default
@INC array. You can use on first line of your script:
#!/usr/bin/perl -I/installs # puts /installs at front of @INC.
or:
push @INC, '/installs'; # puts it at the end of @INC.
or:
use lib '/installs/'; # not sure where this puts it.
But the order is important, if the two modules have identical names.
You might also try:
require '/installs/gd-2.0.15';
Of course, to get mapserver to use the new GD you'll need to recompile
it.
Eric
On Thu, 2003-07-17 at 16:02, Steve Lehr wrote:
> I'm trying to see if gd2.x will solve a limitation in old gd 1.3 that when
> an irregular shaped polygon is rendered it gets white lines on it
> --- | <- problem old gd draws white line here
> |--| | <- Another white line here.
> |_____|
> Ok..
> I have the latest version of GD on my box, my question is how do I get perl
> to pick up a different library with the USE command.
> i.e. use GD; picks up the standard old GD library....I'd like to specify it
> to use /installs/gd-2.0.15
> Is this possible?
> Thanks
> Steven Lehr
> Visiting Professor
> Embry-Riddle Aeronautical University (LB159)
> 600 S. Clyde Morris Blvd.
> Daytona Beach, FL 32114-3900
> 386-226-7740
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Joe Smith
> Sent: Thursday, July 17, 2003 11:05 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Mapscript problems
> Hi,
> I have been working with mapserver for a few weeks now without too much
> trouble, but I've run into some problems trying to get mapscript to compile.
> It runs fine without the --with-php option, but I'm looking to add more
> functionality. I'm actually trying to get mapscript compiled in two
> places - my local linux box where i do the editing, and on the web server.
> It doesn't seem to work on either.
> Here's the specs/problem on the local box:
> Linux 9, apache 2.0.47, php 4.3.2, mapserver 3.6.6
> I know what the problem is ; php isn't compiling with
> the --with-regex=system like it should, and I don't know why. I checked
> phpinfo and the regex section didn't have anything about system. I compile
> php like this:
> ./configure \
> --prefix=/usr/local/www/php \
> --with-config-file-path=/usr/local/www/php \
> --enable-track-vars \
> --enable-force-cgi-redirect \
> --with-regex=system \
> --with-mysql \
> --with-zlib \
> --without-ttf
> make
> make install
> cp -p php.ini-recommended /usr/local/www/php/php.ini
> I tried removing config.cache like some of the posts suggested (and make
> clean), but it did not work. I'm still getting familiar with linux/unix so
> I wouldn't really know where to look if it was using some old version of a
> file in the compile.
> Here's the specs/problem on the web server:
> FreeBSD 4.4, apache 1.3.22, php 4.0.6, mapserver 3.6.6
> When I try to make mapserver, I get this:
> A bunch of undefined references when it gets to php_mapscript.so
> "Stop in /usr/home/joe/mapserver/mapscript/php3"
> "*** Error code 1"
> Here's my configure line for mapserver:
> ./configure --with-gd=/usr/local --with-php=/usr/local/www/include/php
> I do have root access, and apache and php were already running so I don't
> want to mess with them if I don't have to, since it's a virtual server (I
> could probably recompile php though). Is anyone familar with either of
> these problems or have any ideas? Thanks in advance!
> Joe
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
