[Mapserver-users] Installation of MapServer
Michael Schulz
mschulz at webgis.de
Mon Jul 21 08:55:53 EDT 2003
this is likely to happen when the image path and image url parameters of
your web section in the mapfile are not correct.
Image path holds the filesystem path to a directory that is writable by
the user the webserver runs as (and where the map, legend and scalebar
images are created) and image url is the url to access this path through
your webserver.
If your are using the mapserver itasca demo, you have to change the
demo_init.html file and change the values of the hidden input parameters
map_web_imagepath and map_web_imageurl.
Cheers, Michael
"Alexander,Ryan [Dartmouth]" schrieb:
> I followed some steps that I found from the net to install MapServer.
> I can get the first page to load up for the demo but once the map
> appears, if I try to do something with it, I lose my images and the
> map image is just black with a little red 'x' as if the image doesn't
> exist. The same thing occurs with the legend image.
> Wondering if anyone can help.
> Thanks
> Newf
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
