[Mapserver-users] Php Mapscript 4 again : zoom problem
Yewondwossen Assefa
assefa at dmsolutions.ca
Mon Jul 21 18:49:27 EDT 2003
Hi There,
There was a bug in php_mapscript with the drawimageicon function. It
has been corrected in the latest version of CVS. Please give it a try
and let me know. For refernce to this bug or additional comments, you
can check bug 369 of mapserver.
Later,
W. Steph wrote:
> You're totally right !! I think I asked this question to rapidly,
> without searching for a cause before. Now I've found exactly where the
> problem is :
> In my mapFile, I use a "Marker" in my Reference map :
> REFERENCE
> EXTENT 635790.749438 1795645.675 759447.213063 1919170.85
> IMAGE "../images/reference.gif"
> MARKER "Bigcross"
> MARKERSIZE 12
> MINBOXSIZE 10
> MAXBOXSIZE 80
> COLOR 255 180 180
> OUTLINECOLOR 50 0 150
> SIZE 90 90
> STATUS ON
> END
> It doesn't seems to work with the newest versionsof
> mapserver/php-mapscript : as soon as I zoom over the scale of 1 :
> 200000 the box on the reference map becomes the marker symbol
> "Bigcross". Even if I replace the marker with another symbol, it has
> the same result : 30 sec loading exceeded (there must be an infinite
> loop in the code or somtehing like that :/ )
> I also can't use the drawLegendIcon function : it makes php.exe crash
> on the server !
> I don't think the two problems are related.
> But maybe there's a way to solve this problems !
> Steph
>> From: Vincent Schut <schut at sarvision.com>
>> To: "W. Steph" <chewbizz at hotmail.com>, Mapserver-users at lists.gis.umn.edu
>> Subject: Re: [Mapserver-users] Php Mapscript 4 again : zoom problem
>> Date: Fri, 18 Jul 2003 16:56:34 +0200
>> Hi Steph,
>> You'll have to provide more information before any of us can think of
>> any
>> hints, I'm afraid... Like what application do you use to zoom in (or
>> did you
>> program it yourself, if so, how do you zoom in), the contents of your
>> mapfile. Then maybe someone can say something about it. Now your
>> question is
>> simply lacking information.
>> Cheers,
>> Vincent.
>> On Friday 18 July 2003 16:23, W. Steph wrote:
>> > Hello again !
>> > I have a big problem with mapserver 4.0 (beta1, beta2, and last
>> precompiled
>> > windows binaries) and php-mapScript.
>> > With any configuration (one or many layers turned on ; postgis
>> database or
>> > shapefiles) I can't zoom over the scale of 1 : 200000 !! I didn't
>> searched
>> > where the problem comes from, but I'll do it right now.
>> > I'll send more infos when I find.
>> > Do you have any hints ?
>> > Thanks
>> > Steph
>> > _________________________________________________________________
>> > Trouvez l'âme soeur sur MSN Rencontres http://g.msn.fr/FR1000/9551
>> > Mapserver-users mailing list
>> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>> Vincent Schut
>> Sarvision B.V.
>> Wageningen, The Netherlands
>> www.sarvision.com
> Découvrez les nouvelles émoticônes animées de
> http://g.msn.fr/FR1001/866 MSN Messenger nouvelle formule
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
