[Mapserver-users] Php Mapscript 4 again : zoom problem
W. Steph
chewbizz at hotmail.com
Tue Jul 22 04:56:54 EDT 2003
I downloaded the mapscript dll you put in the temp directory, and now
php.exe doesn't crash anymore with drawimageicon. But there are still
problems. It seems that the function doesn't work. If I don't use
drawimageicon but createlegendicon only, some of my layer legend icons are
drawn. The ones with only OUTLINECOLOR or only a SYMBOL are not drawn. So I
thought drawimageicon would draw these. But in fact, it draw nothing :
Not drawn :
CLASS
NAME "Zones d'occupation du sol"
OUTLINECOLOR 200 200 200
END
Not drawn :
CLASS
NAME "Pompiers"
TEMPLATE "Queryable"
SYMBOL "Intervs" # The symbol is ok, it was drawn in older versions !
END
Drawn ! :
CLASS
NAME "Lignes Electriques"
COLOR 0 0 255
END
Here is the code supposed do draw the icons
$lclass = $layertmp->getClass(0);
$lim = $lclass->createLegendIcon(16,16);
$lclass->drawLegendIcon(16,16,$lim,0,0);
$legendurl = $mapServerImagesUrl.($lim->saveWebImage(MS_GIF,1,1,0));
I checked : drawImageIcon returns MS_SUCCESS. So it should be ok ... but not
The worst is for now :
The marker symbol in my mapfile :
The problem is still there : When I zoom under minboxsize, the box should
transform into a marker. But that does not happen : mapserver keeps working
till the 30 sec time limit is reached. I noticed something else since my
last mail : the server memory (very) quickly overflows (ok I have only 128Mb
of RAM on my test server but it overflows anyway)
That's why I think the MARKER problem is different from the drawlegendicon
problem.
Just to thank you again : good work on bug 316 :p
It was very annoying ! Now it's ok ;)
And also thank you for letting users download win32 binaries by putting them
in the temp directory, it's very usefull for user like me who doesn't have
time to compile mapserver or mapscript (Setting up cygwin and learning the
code is quite a long task, and my placement is nearly finished)
Thanks thanks thanks again
Steph
>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>To: "W. Steph" <chewbizz at hotmail.com>
>CC: Mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] Php Mapscript 4 again : zoom problem
>Date: Mon, 21 Jul 2003 18:49:27 -0400
>Hi There,
>There was a bug in php_mapscript with the drawimageicon function. It has
>been corrected in the latest version of CVS. Please give it a try and let
>me know. For refernce to this bug or additional comments, you can check bug
>369 of mapserver.
>Later,
>W. Steph wrote:
>>You're totally right !! I think I asked this question to rapidly, without
>>searching for a cause before. Now I've found exactly where the problem is
>>In my mapFile, I use a "Marker" in my Reference map :
>> REFERENCE
>> EXTENT 635790.749438 1795645.675 759447.213063 1919170.85
>> IMAGE "../images/reference.gif"
>> MARKER "Bigcross"
>> MARKERSIZE 12
>> MINBOXSIZE 10
>> MAXBOXSIZE 80
>> COLOR 255 180 180
>> OUTLINECOLOR 50 0 150
>> SIZE 90 90
>> STATUS ON
>> END
>>It doesn't seems to work with the newest versionsof
>>mapserver/php-mapscript : as soon as I zoom over the scale of 1 : 200000
>>the box on the reference map becomes the marker symbol "Bigcross". Even if
>>I replace the marker with another symbol, it has the same result : 30 sec
>>loading exceeded (there must be an infinite loop in the code or somtehing
>>like that :/ )
>>I also can't use the drawLegendIcon function : it makes php.exe crash on
>>the server !
>>I don't think the two problems are related.
>>But maybe there's a way to solve this problems !
>>Steph
>>>From: Vincent Schut <schut at sarvision.com>
>>>To: "W. Steph" <chewbizz at hotmail.com>, Mapserver-users at lists.gis.umn.edu
>>>Date: Fri, 18 Jul 2003 16:56:34 +0200
>>>Hi Steph,
>>>You'll have to provide more information before any of us can think of any
>>>hints, I'm afraid... Like what application do you use to zoom in (or did
>>>you
>>>program it yourself, if so, how do you zoom in), the contents of your
>>>mapfile. Then maybe someone can say something about it. Now your question
>>>is
>>>simply lacking information.
>>>Cheers,
>>>Vincent.
>>>On Friday 18 July 2003 16:23, W. Steph wrote:
>>> > Hello again !
>>> > I have a big problem with mapserver 4.0 (beta1, beta2, and last
>>>precompiled
>>> > windows binaries) and php-mapScript.
>>> > With any configuration (one or many layers turned on ; postgis
>>>database or
>>> > shapefiles) I can't zoom over the scale of 1 : 200000 !! I didn't
>>>searched
>>> > where the problem comes from, but I'll do it right now.
>>> > I'll send more infos when I find.
>>> > Do you have any hints ?
>>> > Thanks
>>> > Steph
>>> > _________________________________________________________________
>>> > Trouvez l'âme soeur sur MSN Rencontres http://g.msn.fr/FR1000/9551
>>> > Mapserver-users mailing list
>>> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>>Vincent Schut
>>>Sarvision B.V.
>>>Wageningen, The Netherlands
>>>www.sarvision.com
>>Découvrez les nouvelles émoticônes animées de http://g.msn.fr/FR1001/866
>>MSN Messenger nouvelle formule
>Assefa Yewondwossen Software Analyst
>Email: assefa at dmsolutions.ca http://www.dmsolutions.ca/
>Phone: (613) 565-5056 (ext 14)
>Fax: (613) 565-0925
MSN Messenger 6 http://g.msn.fr/FR1001/866 : dialoguez en son et en image
avec vos amis.
