[Mapserver-users] php.exe crash with drawQuery
Daniel Morissette
morissette at dmsolutions.ca
Mon Jul 28 10:57:22 EDT 2003
Steph,
DrawQuery() works for me in all the tests that I make on both Windows
and Linux. I also ran a sequence of Query + DrawQuery() with Valgrind
(a memory checker) and no errors were reported.
So it must be something specific to your data, mapfile or script. If
you can then please file a bug in bugzilla and attach a small
reproduceable test case (script, mapfile and data). Otherwise I don't
think anyone can help without a way to reproduce the problem.
BTW, the reference map marker problem (bug 378) is fixed in the 4.0 CVS.
Daniel
W. Steph wrote:
> Hello again !
> I have a problem with $map->drawQuery() with mapscript 4 : here is my
> php-mapscript code :
> [$queryzone = ..]
> if ($queryselectmode == "clic")
> $success=@$qlay->queryByPoint($queryzone,MS_MULTIPLE,-1);
> else
> $success=@$qlay->queryByRect($queryzone);
> if ($success==MS_SUCCESS)
> for ($o=0; $o<$qlay->getNumResults(); $o++)
> $rcmo = $qlay->getResult($o);
> $queryresults[$qlay->name][$o] = $rcmo->shapeindex;
> $querysucceed=true;
> if ($querysucceed)
> $querymap = $map->drawQuery();
> $querymapimg = $querymap->SaveWebImage(MS_JPG,1,1,$quality);
> This code makes php.exe crash on the line $querymap = $map->drawQuery();
> (with querybypoint _and_ querybyrect) with numerous different test cases.
> But it worked with previous versions...
> I found in the mapServer Wikki that there where MapFiles changes in 4.0,
> and I saw ITEMQUERY and ITEMNQUERY : I don't have these in my mapfile,
> and I don't know what they are used for (I found nothing about it in the
> mapFile reference). Maybe my problem could be solved with this ? Also, I
> didn't change anything in my mapfiles since I use mapserver 4.0; maybe
> there are other things to do but I can't understand everything very well
> on the wikki's migration guide.
> Can somebody help ?
> Thanks a lot
> Steph
