[Mapserver-users] php.exe crash with drawQuery
W. Steph
chewbizz at hotmail.com
Tue Jul 29 03:43:14 EDT 2003
First, thank you for the marker bug. But I can't compile mapscript myself
(not ennough HD space and not enough time to set up the compiling
envirronment and deal with problems)... I will probably wait until there's a
compiled release.
For the drawQuery bug : I investigated a bit more and I think I've found the
problem. You were right, that's not a mapScript problem; it seems to be a
data problem.
A few weeks ago, I was testing the response time of my web application, so I
decided to quadruplate each raw in a PostGis table (changing only the GID).
That seems to be the cause of the php.exe crash. But I don't know why !
(maybe mapserver doesn't like to have equals geometries in the same postgis
table ?)
Now, with all raws having its own geometry (and not a copy of of other raw's
geometry) I still have a problem :
When querying a too large number of shapes (>35) with queryByRect, php keeps
working without stopping, even after the time limit ! (I'm using
set_time_limit(60);) and the problem is still with drawQuery() because the
query is ok, and the returned shape list is ok.
That's definitely a weird behaviour, but it's not really too much annoying.
I know I'm not giving precise information about the problem, but if it can
help to find it....
If I find more clues about it (or another bug), I'll post a mail.
Regards
Steph
>From: Daniel Morissette <morissette at dmsolutions.ca>
>To: "W. Steph" <chewbizz at hotmail.com>
>CC: Mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] php.exe crash with drawQuery
>Date: Mon, 28 Jul 2003 10:57:22 -0400
>Steph,
>DrawQuery() works for me in all the tests that I make on both Windows and
>Linux. I also ran a sequence of Query + DrawQuery() with Valgrind (a
>memory checker) and no errors were reported.
>So it must be something specific to your data, mapfile or script. If you
>can then please file a bug in bugzilla and attach a small reproduceable
>test case (script, mapfile and data). Otherwise I don't think anyone can
>help without a way to reproduce the problem.
>BTW, the reference map marker problem (bug 378) is fixed in the 4.0 CVS.
>Daniel
>W. Steph wrote:
>>Hello again !
>>I have a problem with $map->drawQuery() with mapscript 4 : here is my
>>php-mapscript code :
>>[$queryzone = ..]
>>if ($queryselectmode == "clic")
>> $success=@$qlay->queryByPoint($queryzone,MS_MULTIPLE,-1);
>>else
>> $success=@$qlay->queryByRect($queryzone);
>>if ($success==MS_SUCCESS)
>> for ($o=0; $o<$qlay->getNumResults(); $o++)
>> $rcmo = $qlay->getResult($o);
>> $queryresults[$qlay->name][$o] = $rcmo->shapeindex;
>> $querysucceed=true;
>>if ($querysucceed)
>> $querymap = $map->drawQuery();
>> $querymapimg = $querymap->SaveWebImage(MS_JPG,1,1,$quality);
>>This code makes php.exe crash on the line $querymap = $map->drawQuery();
>>(with querybypoint _and_ querybyrect) with numerous different test cases.
>>But it worked with previous versions...
>>I found in the mapServer Wikki that there where MapFiles changes in 4.0,
>>and I saw ITEMQUERY and ITEMNQUERY : I don't have these in my mapfile, and
>>I don't know what they are used for (I found nothing about it in the
>>mapFile reference). Maybe my problem could be solved with this ? Also, I
>>didn't change anything in my mapfiles since I use mapserver 4.0; maybe
>>there are other things to do but I can't understand everything very well
>>on the wikki's migration guide.
>>Can somebody help ?
>>Thanks a lot
>>Steph
_________________________________________________________________
MSN Messenger 6 http://g.msn.fr/FR1001/866 : plus de personnalisation, plus
de fun pour vous et vos amis
