[Mapserver-users] Labeling polygon features 'without center'
Vinko Vrsalovic
vinko at cprsig.cl
Mon Jul 28 14:25:11 EDT 2003
Hello,
I'm adding polygon features (through $layer->addFeature()), and
I'm setting the text attribute to the feature to label it. My
problem occurs when there is no part of the polygon in the
center of the bounding box, say a V or C shaped polygon, the
label does not appear, when there is part of the polygon in the
center of the bounding box it appears alright. I've tried setting the
position attribute but it has no effect on features, it seems.
Is there a way to work around this without having to create a
'complete' layer?
I'm using 3.7, though not the latest version. I wanted to check
out what do you guys have to say before upgrading.
Thanks a lot,
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
