[Mapserver-users] Labeling polygon features 'without center'
Daniel Morissette
morissette at dmsolutions.ca
Mon Jul 28 15:01:21 EDT 2003
Vinko Vrsalovic wrote:
> I'm adding polygon features (through $layer->addFeature()), and
> I'm setting the text attribute to the feature to label it. My
> problem occurs when there is no part of the polygon in the
> center of the bounding box, say a V or C shaped polygon, the
> label does not appear, when there is part of the polygon in the
> center of the bounding box it appears alright. I've tried setting the
> position attribute but it has no effect on features, it seems.
I'm not sure if that's what you ran into, but there was a problem with
the label position calculation that was fixed not long ago:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=356
perhaps you should try the latest 4.0 from CVS.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
