[Mapserver-users] Labeling polygon features 'without center'
Vinko Vrsalovic
vinko at cprsig.cl
Mon Jul 28 17:57:33 EDT 2003
On Mon, Jul 28, 2003 at 03:01:21PM -0400, Daniel Morissette wrote:
> Vinko Vrsalovic wrote:
> > I'm adding polygon features (through $layer->addFeature()), and
> > I'm setting the text attribute to the feature to label it. My
> > problem occurs when there is no part of the polygon in the
> > center of the bounding box, say a V or C shaped polygon, the
> > label does not appear, when there is part of the polygon in the
> > center of the bounding box it appears alright. I've tried setting the
> > position attribute but it has no effect on features, it seems.
> I'm not sure if that's what you ran into, but there was a problem with
> the label position calculation that was fixed not long ago:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=356
> perhaps you should try the latest 4.0 from CVS.
The latest 4.0 from CVS solved the issue. Thanks a lot.
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
